Onkyo TX-NR616, constantly clicking, no display, no light/led
  • tibimakai
    replied
    Re: Onkyo TX-NR616, constantly clicking, no display, no light/led
    In my opinion, your best bet is to talk to Tjmotter(on the other forum), but he is not showing up much lately. I believe, that he quit repairing these receivers.
  • lcdcaps1
    replied
    i have bee checking everything seems to be checking out fine
    L8002 - 1.0V
    L8004 - 1.4V
    L8006 - 1.0V
    L8932 - 1.3V
    L8942 - 1.8V
    L8952 - 3.3V
    L8962 - 5.2V
  • budwich
    replied
    you need to check for the voltages at the boards / circuits of interest (hdmi and processor / H & K areas).
  • lcdcaps1
    replied
    Nothing is getting hot
    non of the coils
  • lcdcaps1
    replied
    I have tested voltages on the following coils
    L8932 - 1.3V
    L8942 - 1.8V
    L8952 - 3.3V
    L8962 - 5.2V
  • budwich
    replied
    you probably need to look for the source of 3.3v or equivalent that is usually used for logic powering. You don't actually need the actual source (regulator or otherwise) at this point, just check test points on the various boards that show access or provide access to that type of powering so that you can check if it is there or not.
  • lcdcaps1
    replied
    Originally posted by stj View Post
    interesting pdf,
    so are you just connecting the power cord??
    i cant help thinking this thing tries to download something over ethernet!
    really??? not from a usb it shouldnt!!
    I cant get it to do any firmware update
    I am leaning towards a voltage problem where the chips are not being powered
    Can anyone help with this please
    thanks
    replied
    interesting pdf,
    The firmware update should take 15 to 40 minutes
  • lcdcaps1
    replied
    I have been thinking it might be a voltage problem but i cant get to the regulators as they are on the bottom of the board.
    can I do any tests from the top or can i flip the board over with something underneath and test and
    in order to do this do all the cables need to be attached
    Thanks so much
    please can someone help who has worked on these boards
    can someone tell me which regulators please
    thanks so much
  • lcdcaps1
    replied
    Originally posted by R_J View Post
    Have you checked the update procedure that tells you to configure the amp in a certain way before updating the firmware?
    Yes I did but can't see anything on the tv. Can't get the osd to show. So no way me to turn off things. I have done the rest key combination so I assume it's ok
    If you know how to then please post
  • R_J
    replied
    Originally posted by lcdcaps1 View Post
    I saw that but I've tried by usb as well so not sure why it is timing out . what can cause this
  • lcdcaps1
    replied
    I have not seen this error, if you look it up on the internet you will see others that have had it. It says it is a time out error.
  • lcdcaps1
    replied
    Originally posted by budwich View Post
    you might want to check / ensure that those processor boards have the proper electrical conditions (voltage / ground) to allow for proper operation before going down the path of trying to "manually write" the firmware. It is a strong possibility that there is a issue at the board level.
    Can you help with this Please.
    I have one screw in the hdmi port to chassis
    What voltge do I check and where do I check .
  • R_J
    replied
  • budwich
    replied
  • lcdcaps1
    replied
    No I have not.
    ok thanks
    have you ever seen this error i am having
    please can you help
  • R_J
    replied
    have you used uart on these onkyo amps
    No I have not.
  • lcdcaps1
    replied
    I take it you unzipped the 3 files and the 1 directory to the root of a clean FAT32 formatted usb stick.
    Do you get:
    Select the USB input source.
    “Now Initializing...” appears on the AV receiver's
    display and then the name of the USB device is
    displayed. It takes 20 to 30 seconds to recognize the
    USB device.
    yes i done exactly that but it gives me error 5-82 on vsp and vmpu
  • R_J
    replied
    Do you get:
    “Now Initializing...” appears on the AV receiver’s
    USB device.
  • lcdcaps1
    replied
    How did you try and update it via usb if you don't have the firmware? Download it from Oink-E-yo
    i downloaded the official firmware and put it on a USB drive but get an error
    as mentioned
    i read that i can flash the nor chip (q8040) using a chip programmer but i need a firmware dump from another board
    I was also reading that this might be able to be fixed using UART but not sure how
    please i need lots of help
    thanks in advance
