Picked up a 1990 CD player. Noticed the audio sounds slightly distorted on loud passages. Almost like the output was too high. I started poking around and found a transistor getting very hot when the cd is playing. It doesn't get hot when not playing the cd. The part # on the pcb is TR103. The transistor beside it (tr 104) seems fine. Any ideas? I don't have the schematic.
Distorted audio and HOT transistor - Denon DCD-610 CD PLAYER
Tags: None
Re: Distorted audio and HOT transistor - Denon DCD-610 CD PLAYER
see if a resistor is connected to the emitter .then calculate the current . then see what it connects to and see what current it should draw normally .
these things are impossible for me without a schematic . -
It's likely those are spindle motor drive the transistors are for.
The CXA1182 IC drives many transistors in a bridge. The pairs drive the spindle servo, sled motor, tracking coil and focus coil. So four pairs.
Check the power supply voltages. Voltage regs IC501, IC502 look like they've been replaced. Guessing +/-12V from them.
Or the spindle motor is drawing too much current, the brushes do wear out.Comment
Thanks! Will check that. Could the overheating transistor have something to do with the slightly noisy/distorted audio during peak levels or maybe it's just another issue?It's likely those are spindle motor drive the transistors are for.
Thanks! I'll post a pic of the bottom of that section of the pcb to show what it's connected to
Underside of the board ...Attached Filesif you find these attachements useful please consider making a small donation to the site
By the way. I have a DENON dcd-910. It may use the same transport. I'll look at it tonight to see if I can swap transports to troubleshoot.Comment
That transistor is likely focus drive output, (try cleaning the lens) You say the transistor is getting hot but that is likely normal. TR107 seems to have a poor connection on its collector (resolder it) If you don't have a scope it might be hard to troubleshoot the problem.
If the problem seems to be with loud passages, its likely once the signal gets converted to analog.Last edited by R_J; 01-19-2021, 10:57 AM.Comment
Thanks! I'll check that. I did clean the lens earlier yesterday. Luckily, the transports in my dcd-610 and dcd-910 look interchangeable. I think I'll swap drives this evening to see if that affects the slightly distorted audio. Most of the main board in the 610 and 910 are the same as well. I'll check to see if that same transistor in the 910 is getting as hot as this one was. If so, I'll be looking if for another cause of the distortion. I do have a little $30 digital oscilloscope I picked up from Amazon. Haven't had time to start learning how to use it yet.That transistor is likely focus drive output, (try cleaning the lens) You say the transistor is getting hot but that is likely normal. TR107 seems to have a poor connection on its collector (resolder it) If you don't have a scope it might be hard to troubleshoot the problem.
If the problem seems to be with loud passages, its likely once the signal gets converted to analog.Comment
TR103 & TR104 are the focus drive transistors, TR103 collector connects to +10vdc, TR104 collector connects to -10vdc, Check that the + & - voltages are correct. (check when the cd is operating)
Have you tried using the head phone jack to see if the audio is the same?Last edited by R_J; 01-19-2021, 11:45 AM.Comment
Thanks! Will do. So does it stand to reason that they should be the same operating temp? One is super hot. The other is just warm.Comment
It would depend on where it is focusing, it is likely driving the focus coil harder in one direction, there could be a number of reasons for this.Comment
Ok. Issue solved...partially. I opened up my DCD-910 and it's very similar to the 610. It has those same components we've been discussing. That one transistor does get so hot after a few minutes of playing a disc that you can't touch it for more than a few seconds.That transistor is likely focus drive output, (try cleaning the lens) You say the transistor is getting hot but that is likely normal. TR107 seems to have a poor connection on its collector (resolder it) If you don't have a scope it might be hard to troubleshoot the problem.
So that apparently a "fault" and isn't responsible for the distortion. Anyway, I reflowed the solder on several spots on both decks (since I had them open). I'll continue to investigate the distortion. I'll try it with another amp/speaker setup. Thanks!!Comment
Hello everyone !
I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
Feel free to share your experience if you ran into other issues.
DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
CD tray would not come out of the player
I could hear a motor spinning inside the player but the CD tray would not come out.
Turned out that the issue was the CD tray belt that aged poorly and began to...-
11-05-2025, 03:11 AM -
Hello, I have tried to see what could be the problem in this CD-player with no luck.
The service manual for Denon pro gear is hard to come by.
The player loads the CD, spin the disc, but instead of focus adjustment the sled itself is jumping a few millimeters, and tries about 5-6 times and shows "Media Error"
The CD-transport itself has a partnumber of TD-S208PR-6, not much of info able to find.
This can be a problem with the PCB itself, but most often the transport is the problem....-
by ajvpbHi all,
Hobbyist repairman here so I've reached the end of my troubleshooting abilities. The audio out of the FL+FR speakers is very distorted and almost unintelligible. BUT! That only applies to digital audio; Analog plays through just fine. The distortion carries to headphones if those are plugged in with audio from a digital source. All other speaker channels play fine regardless of digital or analog.
Previous experience with similar distorted audio has been bad resistors on the amp output - Could bad smd resistors on the hdmi board cause the same problem? My understanding...-
by DukeWaddtrying to identify this transistor
its from a denon amp where one channel burnt up a couple resistors and transistors....-
This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...09-06-2024, 05:30 PM
- Loading...
