Denon DN-501C CD-player not reading CD
  • PowerAmpFreak
    • 982
    • Sweden
    Hello, I have tried to see what could be the problem in this CD-player with no luck.
    The service manual for Denon pro gear is hard to come by.
    The player loads the CD, spin the disc, but instead of focus adjustment the sled itself is jumping a few millimeters, and tries about 5-6 times and shows "Media Error"
    The CD-transport itself has a partnumber of TD-S208PR-6, not much of info able to find.
    This can be a problem with the PCB itself, but most often the transport is the problem.
  • redwire
    • 3910
    Re: Denon DN-501C CD-player not reading CD
    The sled should move smoothly.
    Commonly I find the transports need lubrication on the rails and worm-shaft. With oil and grease, they get too stiff and can jam/stick gears slip.
    I use light grease on the rails and light oil the worm-shaft only if that matches the factory lube (oil vs. grease) there. It's a grease vs oil question. Clean off the old lube with IPA and Q-tips.
    I would also check the sled home sensor switch is working, that the sled is not too far off in position.
    I thought first step is to spin up the disc, then focus step and look for pulses from the CD pits. If it does not see anything, it must be moving the sled hunting.
    • PowerAmpFreak
      • 982
      • Sweden
      I cleaned the sled with isopropanol there are no difference
      The homeposition switch is measured ok
      Here is a youtube vid of the problem:
      https://youtu.be/HuLwPi6dgaE
      • R_J
        • 9550
        It is very likely the laser pickup has failed.
        • PowerAmpFreak
          • 982
          • Sweden
          Please tell how you came to that conclusion.
          Cause the focus error is so big and pull the sled? Due to no signal from pickup?
          • lotas
            • Jan 2016
            • 4618
            • Russia
            Check all microswitches (for a short circuit), these may be somewhere else.
            • redwire
              • 3910
              If the transport is hunting to see a CD, it can be a mechanical problem (sled too far in) and this has a belt drive for the worm shaft?
              Or an electronic problem, you should find the factory testpoint for the pickup photo detector signal and use an oscilloscope to see if pulses are there. This would indicate the laser and focus servo are OK, data coming in but not the lead in. I think this player has a lot of circuitry in the transport.
              The service manual might be here https://****************/load/audio/denon/279-4-2 but I don't have membership on the russian site. The URL gets blocked out here.
              The middle main board says DN700C so the 501 may also be similar.
              • lotas
                • Jan 2016
                • 4618
                • Russia
                ser. manual
                • PowerAmpFreak
                  • 982
                  • Sweden
                  Thanks a lot. The service manual will help a lot. Thanks
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    Thanks to the service manual I could measure the laser pickup was worn out. The current regulator showed a very much higher value than limit.
                    So a new pickup is ordered.
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      Even after replacing the laser pickup (and desolder the ESD protection) the player behaves exactly the same.
                      During TOC read, there are ZERO output from the RF front-end chip. My question is what level the RF should be on the pick-out itself before the preamp, anyone knows ?
                      (Typically)
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        I had the chance to try another cd drive from another Denon DN unit and that also does not work in this maschine
                        So it seems the fault is in the control board.
                        (The drive works in the other maschine)
                        • PowerAmpFreak
                          • 982
                          • Sweden
                          The original pickup has partnumber EP-HD870PB and I replaced it with SFHD870 after reading some info that it should be compatible, but does anyone know if this is true ?
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            Finally solved. After some more troubleshooting the laser pickup flatcable was faulty, it had several broken strands.
                            After replacing the CD works nicely.
                            • SuperAman
                              PS5 HDMI port diode reading?
                              by SuperAman
                              I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                              02-03-2024, 10:16 PM
                            • Fuzzy Fix
                              0.00 ESR reading on a capacitor
                              by Fuzzy Fix
                              Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                              I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                              Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                              07-26-2024, 12:05 AM
                            • kalilinux25
                              no 3v and 5v section voltage reading
                              by kalilinux25
                              Hi my board is HUSK MB 11309-248.4TU05.021
                              The board is plugg and consuming 13 milliamp
                              measuring the 3v coil no reading and the 5v coil no reading
                              Ive measure the pins in PU4103 ( RT8223M)
                              1- NO READING
                              2- NO READING
                              3- 4.4V
                              4-NO READING
                              5- NO RADING
                              6- NO RADING
                              7-3.3V
                              8- 5V
                              9-19V
                              10- NO RADING
                              11-3.3V
                              12- 3V
                              13-
                              14
                              15
                              16-4.4V
                              17-3.3V
                              18- NO READ
                              19-5V
                              20- NO READING
                              21-2V
                              22-2V
                              23-NO READING
                              24- 5V
                              01-27-2020, 03:01 AM
                            • Thoa
                              Dell Latitude 5440 IDB40 LA-M401P reading the Bios-WSON8 UC2
                              by Thoa
                              Hello Community...
                              I am totaly disappointed, cause i bought a used Dell Latitude 5440 with a cracked display. I ve spend another 50 Euros for the new screen and it does his job very well. Then I reallized that a Bios-Passwort is set. First I bought the CH341A black edition with the clamp and was confidence, that it will do its job, realizing that this does not work. So I decided to buy a pogo-pin-tool to read the UC2 first of all (nothing tried on UC6 Yet). The outcome was very random when reading the WSON 8x6, so I decided to buy the XGecu T48, but it is the same. No reliable data....
                              08-12-2025, 04:05 PM
                            • Cornito
                              Denon AVR-2700H audio stops while receiver still works
                              by Cornito
                              Hello team,
                              I've got a new issue with a Denon Avr-2700H.
                              After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                              Receiver still work and display video with error message on display.
                              Seems to me that is the main output relay.
                              I'm looking for the service manual that I can't find for the moment.
                              Does somebody have it?
                              Regards...
                              08-03-2025, 06:10 AM
