Kenwood RC-R0825 remote failure
  • ex250
    • Jun 2019
    • 97
    • Spain
    Hi, I have this remote not working for the AV amplifier, is it fixable?
    The red led not works with any button, no IR emissions at any key stroke. Stopped working without a drop as far I know.
    Changed bateries, opened to clean pad, checked for broken welding joints, nothing found.
    Any other check that could be done or is definitely dead.
    • 31218
    Re: Kenwood RC-R0825 remote failure
    inside picture?
    • ex250
      • Jun 2019
      • 97
      • Spain
      Here are. Thanks!
      • ex250
        • Jun 2019
        • 97
        • Spain
        I have opened one RC-R0730 and inside is the same board, perhaps only different eprom, because external are identical except the three pin Y1 component (don't know what it is)
        Will make readings to compare the visible resitors if I find some difference.
        If some one could point me some instructions.. any help is appreciated
        • ex250
          • Jun 2019
          • 97
          • Spain
          R9=180,4 ohms
          R5=1,2
          R4=100K
          R10=10 ohm
          R6=100Ohm
          C2= 122-- 96nf
          R35=1,09
          R54=0,002
          On the visible components there aren't much differnces, only the C2 is slightly different. The TP1-TP2 values and others TPx measured are different, but I don't know what they are.
          From the Y1s I unsoldered them and no readings could get on neither one.
          • npielawski
            MacBook Pro late 2016 (820-00239) with multiple failure modes.
            by npielawski
            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
            Today, 01:53 AM
          • cstout
            DeLonghi AC Remote only accepts 3V
            by cstout
            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
            I can't find any schematics...
            06-03-2024, 03:53 PM
          • Mc_Millian
            Toshiba 50lf711u20 fire tv remote not pairing
            by Mc_Millian
            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
            The Tv model number is: 50lf711u20 Rev B.
            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
            I've tried 3 different remotes which should be fully compatible with this TV.
            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
            The power button, along with the volume,back,select, and directional...
            04-07-2022, 12:15 PM
          • edugimeno
            HiSense 55A7500F won't obbey to remote after power on
            by edugimeno
            Hi! I have this TV set that does the following:
            1) I press the red power button on the remote
            2) The TV turns on normally
            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
            Then after it's off, it would again accept the TURN ON from the remote and same again
            BUT:
            -The remote does show the correct IR beam while observed thru a phone camera
            -The TV works fine while using the MiRemote...
            03-14-2023, 11:22 AM
          • rustinjust
            Please help, where can I get a remote for my subwoofer?
            by rustinjust
            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
            Is there...
            10-28-2023, 03:43 AM
