Mackie CR4 amplifier no sound
    Re: Mackie CR4 amplifier no sound
    Q1 and Q2 are the same so all you need to do is to search the web on how to test NPN Transistor, you also have working board for comparison.
    You also need to to test the Voltages and other parts as I listed in my post #39.
    • UserXP
      • Apr 2012
      • 444
      • Serbia
      #42
      OK, sorry for me not knowing. I meant whether it should be removed from the pcb?
        Try it without removing first, you also have working unit to compare the result, if it reads not correct then remove and retest.
        Do not do component testing when the unit is powered, the only time you do the test when the unit is powered is when you do the Voltage testing.
        • UserXP
          • Apr 2012
          • 444
          • Serbia
          #44
          OK, here's what I got. I found that this type of transistor is 2N5551 NPN type. So the base pin is the P end. I placed the positive probe on the P tab, and the negative on the E and C tabs.
          The data sheet says the layout is as follows:
          E---B
          C
          I set the multimeter on diode setting and tested Q1 and Q2. Both show +0.700 value, with the emitter tab having 0.004 higher value than C, and both transistors read almost the same.
            E---B
            C
            So the E-B junction is basically the same for Q1 and Q2 but I do not understand the other readings.
            • UserXP
              • Apr 2012
              • 444
              • Serbia
              #46
              Well, those other readings were the voltage readings when the unit was On I had taken before and into image. Is there another possible component that could make the Qs not to work right?
              On the far right, there is a diode symbol. It says it is Z1, but there is no marking for it in the service specs. It is connected to the Q1 and R88. Could this be a miniature 12V restriction circuit (like the one with Z3 and Z4 zener diode and the two big resistors R1 and R2 that usually scorch the board) needed to provide the 12V for the TDA to be in play mode? Maybe there is something wrong there which makes the wrong voltages you have noticed?
              I am just making a wild guess here.
              • petehall347
                • Jan 2015
                • 4450
                #47
                https://www.badcaps.net/forum/showpo...4&postcount=30
                Z1 3.9v . if shorted the base on q2 will be zero volts thus off .
                R91 might be high
                  Read my post #39 again.
                  Well, I do not see the test Voltage of R88, the resistance test of R81, the testing of Z1.
                  BTW, Are you saying that Q1 ans Q2 Voltage readings are the same as the non-working unit?
                  No way Q1 and Q2 readings of the working unit be the same as the non-working unit. Q2 has to be on, period, for you to get the sound.
                  • UserXP
                    • Apr 2012
                    • 444
                    • Serbia
                    #49
                    How can I test that in circuit and what to replace it with if its faulty? It could be a zener diode, but I can't see the markings on the body and the specs just says Z1 3.9V.
                    • UserXP
                      • Apr 2012
                      • 444
                      • Serbia
                      #50
                      Well, in my post 37 I put the values on the picture of the non working unit.
                      In post 38 I posted values of the working unit in a similar orientation. Some of them are very different.
                      • petehall347
                        • Jan 2015
                        • 4450
                        #51
                        just make sure its not shorted .
                        • UserXP
                          • Apr 2012
                          • 444
                          • Serbia
                          #52
                          Nope, some are very different (see previous post).
                          Sure thing, no problem. I will have to do that tomorrow, though. Thanks, budm.
                            Guys, I reattached my working CR4 PCB and measured the same spots. Everything is almost identical, except for the Pin 5 voltage. On my working CR4 it reads +13.08V in play mode and +19.90V in Mute mode, just as it is supposd to.
                            The voltages on Q1 and Q2 are "almost" the same (the orientation is as their contacts appear on the image above):
                            Q1:
                            Left leg: 000.0v Right leg:-1.9v
                            Base: +2.9v
                            Q2
                            Left leg: 000.5 Right leg: +2.9v
                            Base: +13.8v
                            Voltage reading of working unit per your reports:
                            The R88 also shows this (position from picture above):
                            Upper leg: (+12v)
                            |S|
                            |S|
                            Lower leg: (+2.9v)
                            Left leg = Emitter
                            Right leg = Base
                            Middle leg = Collector
                            So Q1 has correct reading.
                            Q2 is on so the Collector is at 13.8V but the E-B junction Voltage is not right at all, Emitter is 0.50V Base is 2.9V that means the E-B junction Voltage is 2.9V - 0.50V = 2.4V!
                            2N5551 spec: Vb-e sat is 1V, you have 2.4V.
                            https://cdn.badcaps-static.com/pdfs/...f419abb28e.pdf
                            • UserXP
                              • Apr 2012
                              • 444
                              • Serbia
                              #54
                              budm, I was looking at this datasheet:
                              The CR schematics of that area says those two transistors are 2N5551. The datasheet I looked into shows different pad layout in terms of B, C and E for 2N5551 moar-mounted version (unless they made a mistake in labelling the contacts). That's why I "drew" the layout in one of my previous posts like this:
                              E---B
                              ...C...
                              Left Leg --- Right Leg
                              .......Lower Leg........
                              The bias also confirm this. It is a NPN transistor, so when I put the positive probe on the B pad designated by the datasheet, I can measure the forward voltage on E and C with the negative probe. Did I use the wrong document or did I do something wrong?
                              • UserXP
                                • Apr 2012
                                • 444
                                • Serbia
                                #55
                                R91 might be high
                                I tested all the diodes on the board.
                                D1 and Z2 read 0.6V forward foltage. When revesed, they read around 2.3V.
                                Z1 reads 0.6V forward voltage and around 1.2V backwards.
                                R92 reads 15kΩ, and the two resistors with a zig-zag around those Qs read 4.7kΩ, which is all in accordance with the schematics.
                                Also I noticed this: D1 diode (the one the is in parallel with the R77 resistor) shows continuity bothways, but I need to alternate the probles for that. If I put the probes in the red and black fashion on the diode contacts, I can hear a half s second continuity beep and then it stops. When I alternate the probles (black and red), the beep happens again in the same duration. Every successive probe alternation makes that short beep noise on the multimeter. I don't know, maybe it's picking the continuity from the surrounding components or caps.
                                The Z1 and Z2 diodes do not produce the beep on the continutiy check, yet they produce the readings I typed above. If one of them were shorted, I guess I would have heard a continuous beep.
                                • petehall347
                                  • Jan 2015
                                  • 4450
                                  #56
                                  how about R91 5.6k ?
                                  • UserXP
                                    • Apr 2012
                                    • 444
                                    • Serbia
                                    #57
                                    Yes, it reads 5.66kohm. The one above (R22) reads 9.9-10kohm.
                                    • petehall347
                                      • Jan 2015
                                      • 4450
                                      #58
                                      Q2 is the prime suspect .
                                      i suppose you could try a jumper between C and E of Q2 and see if it plays sound then .
                                      • UserXP
                                        • Apr 2012
                                        • 444
                                        • Serbia
                                        #59
                                        Would that safe to do? I mean, I wouldn't want to damage anything else in the circuit.
                                        • petehall347
                                          • Jan 2015
                                          • 4450
                                          #60
                                          it should be ok so long as you dont short anything else and you short the correct points .
                                          you could wait to see what budm says in case i am missing something
                                          • soeren
                                            A2442 - No sound over internal speakers and no video playback
                                            by soeren
                                            I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                            All happened after the battery ran out of power overall several days when I was on vacation.
                                            I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                            07-26-2024, 01:24 AM
                                          • eduaqa
                                            Amplifier - bad sound when loud sound on bass
                                            by eduaqa
                                            I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                                            I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                                            08-06-2022, 11:28 AM
                                          • Francesc V.
                                            Tele-master AS-20 amplifier. No output sound, just noise
                                            by Francesc V.
                                            Hi:
                                            I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                                            I've checked fuses and all are ok.
                                            I've continued with capacitors:
                                            • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                                            • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                                            The 4 transitors are perfect. Desoldered and tested individually.
                                            There are also components which I don't know exactly what they are....
                                            02-16-2023, 07:55 AM
                                          • osamageris
                                            Sound Amplifier PA1240A JPA_Amp_1240A_Protection_Diagram
                                            by osamageris
                                            PA1240A JPA_Amp_1240A_Protection_Diagram...
                                            Badcaps Electronics Repair Forum & Schematic Search
                                            01-10-2025, 05:34 AM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
