No headphone output from electronic drum kit, which capacitors to replace?
  • Bassquake
    • Aug 2009
    • 19
    I have a Session Pro DD505 electronic drum kit which no longer has sound coming out of headphone jack. The Line Out Left and Right outputs are fine though.
    I replaced the headphone socket to rule out a connection issue.
    I suspect its the caps as it worked for a while, then the sound started "blipping" and failing, and now no sound. They all look fine. But am not sure which ones to replace. Maybe the bottom 6?
    I've attached some photos of the device.
    Help appreciated.
    • 31218
    Re: No headphone output from electronic drum kit, which capacitors to replace?
    i cant read the number, but concentrate on that 8pin TDA amplifier between the caps.
    it may be bad, or it may have lost power.
    it wont be caps unless they are power related because you wouldnt have both channels effected - presuming it's actually stereo
    • Bassquake
      • Aug 2009
      • 19
      Hi. The chip is a TDA1308.
      I did a volt check on the pins. See image below for result. I dont know if theyre ok or not as I dont know much about ICs!
        • 31218
        data
          • 31218
          strange readings, the outputs are equal to the inputs
          • petehall347
            • Jan 2015
            • 4440
            • United Kingdom
            where did you put your black meter probe ? and is that v or mv ?
            • redwire
              • 3912
              Voltages on U18 TDA1308 look fine, single 5V supply so 1/2 that on all ins and outs.
              Q6 and the other might be muting transistors which also get damaged from ESD when you plug in headphones, there can be quite a zap.
              With headphones plugged in, touching a multimeter probe to U18 inputs pin 2, 6 should make noise you can hear.
              • Bassquake
                • Aug 2009
                • 19
                Black was on pin 4. Multimeter was set on 20 on the VDC setting.
                • Bassquake
                  • Aug 2009
                  • 19
                  Should the device be on for this? And do you mean to short pin 2 and 6? Or do mean just prod those pins and I should hear something?
                  • redwire
                    • 3912
                    It's what I would do as a quick test- with the unit powered up, just touch the multimeter's probe to either pin 2 or pin 6 and listen for the click/hum buzz in the headphones. Looking for signs of life there. Do you hear anything at all, thumps or clicks, powering up/down?
                    I would also trace Q6 connections and see if it is a muting transistor for the headphone output. A theory is one L/R has shorted.
                    • Bassquake
                      • Aug 2009
                      • 19
                      After poking around some more (literally!), I found if I pushed using plastic tweezers on the black resistor (I assume its a resistor) marked on the photo below, the sound would return!
                      So I thought I'd resolder its joints if its a cold join but it immediately broke which tells me the resistor was already damaged. One of the sides contacts came clean off.
                      I assume its a resistor so hoping you guys can tell me. And how can I find out its value as I can't get a reading on it.
                      Edit: Looking at the text box next to those smds it looks like its L3 (attached pic). Is that a diode?
                        • 31218
                        it's an inductor - you can probably get away with a jump wire
                        • Bassquake
                          • Aug 2009
                          • 19
                          Oh right. Before I try that. Do they come in different values? If so, how'd you find it out so I can buy some just in case? I managed to get a Ohm reading of 00.3 when set to 200 on the multimeter if that helps? I got same reading on the L2 and L1.
                          Edit: I jumped the L3 and I get sound normally in Right channel now. No sound in Left though.
                          • Bassquake
                            • Aug 2009
                            • 19
                            Ok. I figured out the Left channel issue. Apparently the trace to L1 wasnt working so put a wire in and it works now. See photos.
                            You'll notice I jumped L3 too. Now get sound from both channels.
                            Thanks for all the help everyone. 👍
                              • 31218
                              to answer your other question, they do come in different values,
                              but without the schematic or a component analyzer / LCR meter you have no way to know the value.
                              • Bassquake
                                • Aug 2009
                                • 19
                                Yeh, I've ordered an inductance meter so I can find out. Been needing one anyway! Thanks.
                                • FrancescoV
                                  Onkyo HT-R390 no sound output, video output ok
                                  by FrancescoV
                                  Good morning everyone,
                                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                  The firmware reported is the following:
                                  M:1.00/11107BLP
                                  D:?.??/????????
                                  O:1.00/11107AL
                                  The DSP firmware given the question marks seems corrupt.
                                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                  05-11-2025, 02:59 AM
                                • paparazzo79
                                  mini PC HP Elitedesk connecting speakers to headphone output?
                                  by paparazzo79
                                  Hi guys.
                                  I have this mini PC HP Elitedesk which has 2 headphone outputs on front.
                                  May I connect speakers with/without amplifier to that output without harm to the PC?
                                  I have 2 types of speakers regular one without amplifier (just getting power over usb port) and second type is 2.1 system with subwoofer (probably have amplifier on sub).
                                  I may also buy USB sound card but I see that card has also headphone output marked with headphone icon.
                                  08-19-2023, 12:33 AM
                                • quickname
                                  Cyberpower 1500AVR UPS repair
                                  by quickname
                                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                  I decided to verify that the batteries were...
                                  11-12-2023, 09:57 AM
                                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                  by sam_sam_sam
                                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                  I bought this from an eBay seller but unfortunately they only had one
                                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                  I bought three of from them to also make battery packs with this output power limit in mind
                                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                  04-23-2025, 05:50 AM
                                • mikkele86
                                  Luxman R-5045 - Capacitor at amplifier output broke, can i replace with higher capacitance ?
                                  by mikkele86
                                  Hello Im renovation a Luxman R-5045
                                  On the attached picture there is a cap 0.047uF (47nF) and a resistor, 10ohm. What is their purpose ? and what would happend if I were to replace the caps with lets say, 10nF or 100nF ?
                                  because thats what i got in stock :/
                                  04-16-2024, 12:37 PM
