Philips HTS7140 Soundbar
  • zyklop
    Philips Soundbar TAB8507B/10 stopped working
    by zyklop
    Helllo everybody....
    i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
    Inbetween it has one time started, but no more yet.
    Is anybody who has schetatic or service maual ?!
    Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
    No thermal hotspots or something else controlled with thermal imaging cam.
    No reaction on remote control (function ok, can see it while glow into mobile-camera)
    No shorts to detect.
    ALso tested all reset procederes...
    07-07-2025, 05:08 AM
  • StasNep
    Philips HTL6140B/12 SoundBar no power
    by StasNep
    Hello
    I have got a defective Philips HTL6140B/12 SoundBar, no power from button or remote.
    The power supply is external and working correctly, even tried another one.
    Checked caps with esr meter and all seems ok.
    Checked various resistors and smd capacitors and they seems ok.
    Please help to diagnose this SoundBar.
    Thanks ...
    02-20-2022, 10:37 AM
  • ngml
    Repair of an LG split AC system indoor unit PCB
    by ngml
    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
    This indicates an error in the communication between the outdoor and the indoor unit.
    The outdoor unit is fine, so the problem is the indoor PCB.
    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
    Does anybody have the schematics of this board,...
    02-01-2025, 12:55 PM
  • Sharpa
    Repair attempt Philips 55OLED804/12
    by Sharpa
    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
    The symptoms when bought: Philips logo appears then tv turns off
    Things tried so far:
    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
    Today, 08:30 AM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
