Sennheiser Ew100/G2 Wireless Mic Receiver
  • falcontech
    replied
    Re: Sennheiser Ew100/G2 Wireless Mic Receiver
    on the fuse the acronym is x075f 24v, that cylindrical part I did not understand what component it is if you can give me a hand through service manual I would be grateful
    replied
    Originally posted by falcontech
    I tested the voltages, I realized that at the input of this resettable fuse I have 16 volts at the input and then at the output I have 8.5 volts do you think this could be the problem?
    What is the P/N printed on it, I see XD75????, 24V
    Unplug the DC jack and let the fuse cool down then check the resistance of the fuse.
    Also check the resistance of that black cylinder device connected to that fuse also.
  • falcontech
    replied
    replied
    You should be able to test the input and output Voltage easily, you should also check the resistance of the output to see if it shows very low Ohms or not, nothing special or hard about doing simple test.
  • falcontech
    replied
    Re: Ricevitore microfono wireless Sennheiser Ew100/G2
    Originally posted by budm
    What are the input and output Voltages you are getting on this +8V regulator?
    I'm waiting for you to come to assemble it and then I'll tell you, with what I took apart I only remember the output voltage which was about 6 volts
    replied
    I disassembled the 78m08 voltage regulator, and I am waiting for the new one to be replaced to replace it, I keep you updated
  • falcontech
    replied
  • falcontech
    replied
    I test what you asked for and I will let you know
    replied
    It is not regulated power supply so the output will be higher than 13V without load, it will be 13V with 250mA load.
    What Voltage do you get at the dc jack when the unit is turned on?
    There are many power supplies on that receiver unit, look at page 14, 15, 19, 20 of the service manual, it shows you the Voltage test points that you need to check. Did you check them?
  • falcontech
    replied
    might need a load on it
    I understand what you mean, tomorrow I will test with the receiver on
  • falcontech
    replied
    Originally posted by stj
    can you open that, or is it glued shut?
    it can be opened but at the moment the power supply is not the problem, because it will be replaced, but the receiver that gives that problem, look at the video that I put on youtube
  • petehall347
    replied
    replied
  • falcontech
    replied
    here are the pictures
  • falcontech
    replied
    in a while I attach the photo, however it is the original of the sennheiser NT2, I tried with another power supply but the problem remains, surely some component is gone and I thought about the voltage regulator 78m08
    replied
    hello everyone I have a problem with the receiver of this microphone which is a sennheiser ew100 / G2, attached the photo of the main board and the service manual of the receiver, and I'll put the youtube link for the video of the problem I don't know if it is a power problem, for the moment I realized that the power supply should bring out 13VDC but almost 19 come out, it is not a display problem, because when it starts doing this problem (after a few seconds) the transmitter stops working. I await your advice thank you
    So your AC adapter is putting out 19VDC instead of 13V?
    The service manual page 5 shows DC input jack rating of 10.5 ~ 16V 200mA, nominal is 12V.
    Show us the pictures of the AC adapter you are using.
  • falcontech
    replied
    https://www.youtube.com/watch?v=b8fOD7irM-I
  • falcontech
    started a topic Sennheiser Ew100/G2 Wireless Mic Receiver
  • wolf1976
    wireless receiver for 6 speeds fan control with remote control
    by wolf1976
    hi i have a receiver that is destroyed from the overvoltage i guess
    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
    the motor fan has not label
    i have an other receiver operational
    In your opinion can i measure the voltage at the output ?
    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
    thanks in advance...
    07-23-2025, 03:12 PM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • litsnsirn
    Alienware Aurora R12 with AX1650 wireless adapter problem
    by litsnsirn
    I have an Alienware Aurora R12 desktop and I recently just started reloading the hard drive after replacing one that failed. After reloading the wireless will not work. It comes up in the Device Manager as Intel AX201 and has the warning symbol and if you click into it, it says ‘Code 10 Cannot start’. I’ve tried uninstalling everything that seems related in the software center and the driver, and have tried reloading with two of the different files that I sourced from Dell and a driver package directly from Intel and after reinstalling, it winds up in the same condition that it started....
    11-19-2024, 11:14 AM
  • pulper111
    Pioneer VSX-1123 Receiver - weird voltage problem
    by pulper111
    Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
    I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
    09-02-2020, 11:12 AM
    HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-06-2024, 03:30 PM
