Sennheiser Ew100/G2 Wireless Mic Receiver
  • falcontech
    replied
    Re: Sennheiser Ew100/G2 Wireless Mic Receiver
    In the afternoon I will test the points you asked me on page 29 of the service manual, I think it is useless to test those of the board on page 31 because that is the RF Board and it is a separate body of the Main Board and even without RF Board connected the problem is the same present
    replied
    Originally posted by falcontech
    ok I will try to do these tests, I have to put a probe on gnd and with the other test the resistance points?
    Yes, you will test the resistance of each one of the test points, hopefully we will not find any shorts or very low Ohms readings.
  • falcontech
    replied
    replied
    BTW, page 29 and 31 of the service manual shows the location of the test points on the board.
    replied
    sure that I did those tests, because they were quite understandable to do, I'm asking you to help me to understand where to put your hands in order not to make wrong measurements and unfortunately looking at the scheme of the service manual I can not understand where these points are, that's all
    OK then since you are are able to test those test point on page 14 as I asked before in my post #10, then just use the same test points you did per page 14 but check the resistance this time instead.
  • falcontech
    replied
    replied
    Your post #31
    I try, it will be difficult for me to identify those points on the real card, unfortunately I have a bit of difficulty in interpreting those points from the diagram you sent me, you could be kind enough to point them to me on the photo of the real card thanks
    I am a little confused here since in the other post I ask you to check the test points ad indicated in the service manual way back in my post #10.
    My post #10: "There are many power supplies on that receiver unit, look at page 14, 15, 19, 20 of the service manual, it shows you the Voltage test points that you need to check. Did you check them?"
    So you never did perform those tests since now you are telling me you do not understand how to get to those test points?
  • falcontech
    replied
    let me know if they are ok
    replied
    If you need it, I can take a better picture of the card
    I will need good clear straight shots of the whole top side of the board to start with.
    BTW, do not replace that 8V regulator that you thought it is bad.
  • falcontech
    replied
  • falcontech
    replied
    replied
    You also need to check the resistance with ref to GND on those test points I marked BEFORE you try to power up the unit again.
    replied
    ah ok you are asking me to replace the fuse if I understand correctly ... I ordered them and they are waiting for them to arrive
    I suggest to use regular fuse to perform the test for now until you receive the new fuse, you should also check the resistance of the new fuse before and after you solder it in (you have to wait for the fuse to cool down first after soldering then check the resistance).
    Also read page 141 of the fuse spec sheet regarding to reflow and rework.
  • falcontech
    replied
    Originally posted by budm
    5.20 Ohm at room temperature is bad, the spec is rated at 0.09 Ohms Min. to 0.29 Ohms Max at room temperature.
    You can solder in 0.75A fuses in place for testing for now.
  • falcontech
    replied
    I don't quite understand what should I do with the fuse, should I unplug it and try it? or what?
    replied
    the fuse marks me 05.2 Ohm, the diode marks me 0.028 MOhm
  • falcontech
    replied
  • falcontech
    replied
    perfect i will do what you asked me thanks
    replied
    [QUOTE=falcontech;979358]on the fuse the acronym is x075f 24v, that cylindrical part I did not understand what component it is if you can give me a hand through service manual I would be grateful[/QUOTE]
    1) That black component is a protection diode D210 (SM4007) in case the unit is connected to the wrong polarity of the AC/DC adapter. So check the RESISTANCE as I requested.
    2) Fuse F210 (X075F 24V) is rated at 0.75A per schematic. Did you check the resistance (no power applied to the unit for at least 10 minutes) as I requested?
    3) You must follow my instructions when I request you to do the measurement otherwise we are just wasting times here.
  • R_J
    replied
    The cylindrical part is likely D210 SM4007, polarity protection diode
  • wolf1976
    wireless receiver for 6 speeds fan control with remote control
    by wolf1976
    hi i have a receiver that is destroyed from the overvoltage i guess
    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
    the motor fan has not label
    i have an other receiver operational
    In your opinion can i measure the voltage at the output ?
    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
    thanks in advance...
    07-23-2025, 03:12 PM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • litsnsirn
    Alienware Aurora R12 with AX1650 wireless adapter problem
    by litsnsirn
    I have an Alienware Aurora R12 desktop and I recently just started reloading the hard drive after replacing one that failed. After reloading the wireless will not work. It comes up in the Device Manager as Intel AX201 and has the warning symbol and if you click into it, it says ‘Code 10 Cannot start’. I’ve tried uninstalling everything that seems related in the software center and the driver, and have tried reloading with two of the different files that I sourced from Dell and a driver package directly from Intel and after reinstalling, it winds up in the same condition that it started....
    11-19-2024, 11:14 AM
  • pulper111
    Pioneer VSX-1123 Receiver - weird voltage problem
    by pulper111
    Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
    I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
    09-02-2020, 11:12 AM
    HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-06-2024, 03:30 PM
