Carvin PA620 - Need help finding replacment caps
  • weirdlookinguy
    • Sep 2007
    • 1638
    The amp we use to play music in auto shop at school crapped out the other day. It works but there is a loud arcing sound when you turn it on, and there is buzzing in the output after about 5 minutes of operation. The auto teacher and I are buddies, so he asked me if I could take a look at it for him. I brought it home and opened it up. BADCAPS!! They smell like shit and all splooged out the bottom. Sadly, this amplifier is Made In USA. Too bad the caps aren't!!!
    Here's all the cap values - can you guys help me figure out what series Panasonic caps I should replace them with? All the caps have the Carvin name on them and are marked 105C. There is no series denotation.
    4700uf 50v x2
    1000uf 25v x6
    Would Panny FC work?
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Carvin PA620 - Need help finding replacment caps
    Hey guys. Had to get the order in about half an hour ago, so I ended up going with Panny FC for the 1000uf caps and Nichicon VZ (105c) for the 4700uf caps.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      FC are probably okay but with original specs can't say for sure.
      I'd use Panny FM just to be covered.
      Price usually isn't much different.
      Mann-Made Global Warming.
      - Dr Seuss
      • weirdlookinguy
        • Sep 2007
        • 1638
        Caps came in. The install went without issue with my new 40w station I just got. The amplifier came up beautifully and sounds better than before (bass seems to have more of a punch to it). Those Panny FCs look sexy compared to the crappy old caps that were in there. Interesting observation: the new Pannys (exact same uf and voltage) were the same diameter as the old caps, but almost twice the height. Anyway, I'm glad to see this amp running properly again. Its a very nice, sturdy amplifier and the build quality is very good sans the caps. Hopefully it will still be bumping tunes down in auto long after I leave High School.
        • Player2
          • Aug 2009
          • 98
          The original caps were probably over-rated.
          I worked on a Carvin amp not too long ago for my girlfriend's brother, just replacing some worn out 1/4" jacks. I was not too impressed with the build quality, there was a good reason why the jacks broke. The amp was relatively new. While I was in there, I noticed a bunch of CrapXon caps... he didn't want me to replace them, but I told him he knows where to find me when he runs into problems again
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
