Altec Lancing ACS41
    Altec Lancing ACS41
    These are pictures and spec sheets of the IC's
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Altec Lancing ACS41
    I still have this system on my computer. It has worked quite well over the years and still sounds superb. Music is smooth and clear. Newer systems I tried don't give me that 'thump' I like to hear. Good one, budm.
    • redwire
      • 3912
      These are good systems and worth repair/recap. I have an ACS48 coming in for repair and it looks really well built.
      You can change out the LM324 for a better op-amp with less cross-over distortion, which cleans it up.
        • 12206
        • U.S.
        Hello Redwire, can you tell me what to replace the KIA324P with and should I replace both, that's if I get them working again.
        • redwire
          • 3912
          I know the LM324 has a gritty sound/mid-range blare to it due to the cross-over distortion so I change them out. Quad op-amp alternates:
          LM837 is older and drop in. OPA4134 is very good as well.
          The LM833 and OPA2134 are the high performance duals, to ditch the NJM4560 but it is not as bad.
            • 12206
            • U.S.
            Thank you.
              TA8248, TA8229. Notes: (***V) Voltage with headphone plugged in. When headphone is plugged in the VCC2 from the switched headphone jack is cutoff so there will no VCC2 on pin 8 of the TA chip.
              Pin 1: N.C.
              Pin 2: Bootstrap 2 =18.20V (0.56V)
              Pin 3: Output 2 = 9.42V (0.51V)
              Pin 4: VCC1 = 18.47V (18.47V)
              Pin 5: Output 1 = 9.03V (1.00V)
              Pin 6: Bootstrap 1 = 18.16V (0.52V)
              Pin 7: PWR-GND
              Pin 8: VCC2 = 18.47 (0.05V)
              Pin 9: Ripple filter = 9.63V (0.51V)
              Pin 10: NF1 (Negative Feedback 1) = 0.60V (0.95V)
              Pin 11: Input 1 = 0.06V (0V)
              Pin 12: Input 2 = 0.02V (0V)
              Pin 13: NF2 (Negative Feedback 2) = 0.60V (0.56V)
              Pin 14: Pre-Gnd 1
              Pin 15: Pre-Gnd 2
              • David Stroe
                AOC CQ27G2U/BK - in need of data sheets
                by David Stroe
                I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
                I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
                Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
                Main Board: 715G9500-M0C-B00-005K
                T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
                If someone could please provide any of these data sheets, it would be awesome....
                05-31-2025, 11:12 AM
              • Raulnn
                clean hisense inner sheets
                by Raulnn
                Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
                01-22-2023, 05:19 PM
              • reformatt
                Intel iMacs, 3rd party SSD failures and Fusion setups
                by reformatt
                I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                12-18-2024, 10:34 PM
              • BOSCHNJAK
                by BOSCHNJAK
                ABOUT ME INTRODUCTION FILE
                2
                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                2022 BEV, PROJECT ?
                2021 BEV, PROJECT ?
                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                12-28-2023, 02:09 PM
              • yuzupatogik
                Help with replacing Capacitors on Altec Lansing ATP 3
                by yuzupatogik
                I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                I can't find datasheets for the Samxon in any of the following variants:
                10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                02-14-2025, 04:11 PM
