Yamaha RX-V483 - dead
  • ponteley
    • May 2020
    Yamaha RX-V483 dead. No 5.5V on secondary.
    Tested all fuses, diodes, transistors and caps.
    Unsoldered transformer, - seems to ring trough on all coils. Fuses are OK. Primary DC voltage 160V. I suspect 3A453 IC, but I can't find replacement or substitute anywhere.
    Please help.
    Thank you.
  • easy_mike
    • Dec 2010
    Re: Yamaha RX-V483 - dead
    Do you have a schematic or service manual?
    - does 3A453 IC get the supply voltage?
    - are there any optocouplers on that board?
    - does the circuit make any sound whatsoever when turned on? Clicks, silent beeps?
    • redwire
      • Dec 2010
      • 3912
      OP why did you cross-post pics here and leave us nothing?
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • hemant_2222
        Yamaha RX-A1020 full dead
        by hemant_2222
        Hello Everyone,
        Greetings!
        It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
        09-14-2024, 11:25 AM
      • Hw31
        playstation 5 ps5 disc edition - cfi 1116a - dead short on one side of 4 fuses: f7001 f5402 f7003 f7002
        by Hw31
        hey folks,
        any idea where those pads are lead to? maybe the southbridge? hopefully not the apu. the fuses are ok. the shorted side is marked with an arrow.
        thx...
        02-09-2024, 12:56 PM
      • roadrash
        Yamaha HTA-5630RDS Amplifier dead
        by roadrash
        Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
        12-12-2024, 10:19 AM
      • double_DD
        How can I be sure that my EC chip is dead?
        by double_DD
        As the title suggests, how can I be sure that my EC chip is really dead?
        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
        03-12-2025, 07:47 AM
