Korg i5s - Strange Sound
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Re: Korg i5s - Strange Sound
    is there a reset procedure in the manual ?
    I think yes it have but for real truth i don't find it...
    • z1zmail
      • Jan 2025
      • Italia
      Ciao, hai poi risolto questo guasto?
      • z1zmail
        • Jan 2025
        • Italia
        Ciao, sei riuscito a trovare la causa del rumore?
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • UserXP
          Mackie CR4 amplifier no sound
          by UserXP
          Hi, people.
          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
          10-17-2020, 05:06 PM
        • eduaqa
          Amplifier - bad sound when loud sound on bass
          by eduaqa
          I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
          I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
          08-06-2022, 11:28 AM
        • Francesc V.
          Tele-master AS-20 amplifier. No output sound, just noise
          by Francesc V.
          Hi:
          I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
          I've checked fuses and all are ok.
          I've continued with capacitors:
          • The main black one should have 4700uF, but it has lost half of its capacity during these years.
          • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
          The 4 transitors are perfect. Desoldered and tested individually.
          There are also components which I don't know exactly what they are....
          02-16-2023, 07:55 AM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
