Korg i5s - Strange Sound
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Hello people, I have one Korg i5s, that makes a strange sound every time.
    Sounds like impulse delayed explosions, some times after some time goes away and come back again rising his volume...
    Desturbing a lot the correct function of keyboard.
    I already change all capacitors from main board, and change the amplifier IC for new one from amplifier board because sometimes the sound only works on one speaker at the beginning (Now fixed).
    But the impulse sound still all the time here.
    I try to find something online but no lucky about this issue, could anyone help me to discover what kind of component or IC I need to check and is possible to cause this?
    Thanks for all
  • petehall347
    • Jan 2015
    • 4428
    Re: Korg i5s - Strange Sound
    transistor breaking down maybe .
    • nrcslim89
      • Nov 2019
      • 129
      • Portugal
      Thanks for your reply, should i change the two transistors i have on amplifier board ?
      I have 2 NPN Transistors
      2SC2785
      • petehall347
        • Jan 2015
        • 4428
        it could be from the power supply . hard to say really
        • nrcslim89
          • Nov 2019
          • 129
          • Portugal
          I don't mind to change the transistor from power supply and amplifier board but... i would like to know if the reason could be them...
          Or if it could be a resistor... but there's no signal of blown component...
          • petehall347
            • Jan 2015
            • 4428
            symptoms say transistor ..you might find it with freeze spray
            • nrcslim89
              • Nov 2019
              • 129
              • Portugal
              Hello, thanks for your support, ok, i was checking at Amplifier board and PSU board for transitors.
              On Amp Board i have two "2SC2785" i already remove and put another NPN Transistor, board work and do the same...
              First i try with only one changed and after i try with the two changed...
              Sound keeps always...
              Now on PSU... the only thing i really see is voltage regulators only and bridge rectifiers (RBA-402).
              Could that be the cause?
              Another point is one of the Rectifier Bridges don't have dissipator/thermal protector from factory and under it, i have a little yellow color on around solder joints... not too much but could be a clue ?
              • petehall347
                • Jan 2015
                • 4428
                can you record the sound and post it here ?
                • nrcslim89
                  • Nov 2019
                  • 129
                  • Portugal
                  Sure, sorry my delay, I think it's easy to understand the sound but if you need more information or anything just say.
                  Hope you could help me.
                  • petehall347
                    • Jan 2015
                    • 4428
                    that is a strange sound and not what i expected .
                    i say its like a reverb sound on a loop .
                    i suspect if you disconnect the input to the amp the noise will stop .
                    does everything work as it should ?
                    • nrcslim89
                      • Nov 2019
                      • 129
                      • Portugal
                      Hello thanks for that, yes everything work fine, well for me in my opinion is the first time I try to repair one equipment like this.
                      But all keys work.
                      LCD work, seems everything full working, but the only thing it won't go is that sound, but... One thing is when I change the effects and disable them the sound almost goe away...
                      • petehall347
                        • Jan 2015
                        • 4428
                        you might need an oscilloscope to trace where the noise is coming from .
                        • nrcslim89
                          • Nov 2019
                          • 129
                          • Portugal
                          Ohhh, now you make still bad... I don't have one...
                          And there's no site with new pcb to buy.... For replace.
                          • petehall347
                            • Jan 2015
                            • 4428
                            best you can do is check all connections and power supply voltages . and look closely for anything that looks wrong .
                            • nrcslim89
                              • Nov 2019
                              • 129
                              • Portugal
                              I already replace the rectifier bridges on PSU and the Big Capacitors too.
                              So resuming all:
                              Replace Amplifier IC;
                              Replace all Logic/Main Board capacitors;
                              Replace PSU Big Capacitors and 2 Big Rectifier Bridges.
                              Everything works fine but still having the sound always pulsing.
                              The only thing i can say is when i turn off all effects off, seems the sound goes away or still there but in very low volume.
                              Could this be from any FX IC on Main board ?
                              • petehall347
                                • Jan 2015
                                • 4428
                                yes it sounds like its from effects .maybe corrosion on ic pins . hard to say
                                • nrcslim89
                                  • Nov 2019
                                  • 129
                                  • Portugal
                                  Thanks once more, could you please point me to something using the service manual ?
                                  • petehall347
                                    • Jan 2015
                                    • 4428
                                    you could try as many tests as you can mentioned in the manual and see if it reveals anything .
                                    • nrcslim89
                                      • Nov 2019
                                      • 129
                                      • Portugal
                                      Today, i assemble the keyboard, and try to disable the audio effects.
                                      And guess what?
                                      Yeah the problem goes away, assuming this could be a effect.
                                      So the problem is effects must be off, but i have to do it, everytime i turn ON the keyboard.
                                      Seems to be a default configuration made by someone or old user.
                                      I don't know how to save no effects.
                                      Another thing is now i just have sound on one speaker =(
                                      Could you help me how to save no effects and troubleshoot the malfunciontion of the speaker ?
                                      • petehall347
                                        • Jan 2015
                                        • 4428
                                        is there a reset procedure in the manual ?
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • UserXP
                                          Mackie CR4 amplifier no sound
                                          by UserXP
                                          Hi, people.
                                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                          10-17-2020, 05:06 PM
                                        • eduaqa
                                          Amplifier - bad sound when loud sound on bass
                                          by eduaqa
                                          I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                                          I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                                          08-06-2022, 11:28 AM
                                        • Francesc V.
                                          Tele-master AS-20 amplifier. No output sound, just noise
                                          by Francesc V.
                                          Hi:
                                          I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                                          I've checked fuses and all are ok.
                                          I've continued with capacitors:
                                          • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                                          • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                                          The 4 transitors are perfect. Desoldered and tested individually.
                                          There are also components which I don't know exactly what they are....
                                          02-16-2023, 07:55 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
