Yamaha RX-V577 - DC: PRT 000L
  • stinkincaps
    • May 2020
    • 18
    Manual says DC output of power amplifier is abnormal.
    Power supply board looks to be ok, 5.5V is good.
    Looks like I need to go deeper, where do I start?
  • R_J
    • 9555
    Re: Yamaha RX-V577 - DC: PRT 000L
    Check for shorted output transistors
    • stinkincaps
      • May 2020
      • 18
      Thanks for the tip. So I'm looking on the MAIN amp board, powered off, measuring impedance on all transistors. Will have to do some disassembly first to get to them all.
      • stinkincaps
        • May 2020
        • 18
        Ok, the big transistors on the heat sink all seem to be not-shorted. Any advice on next step?
        Thanks in advance.
        • R_J
          • 9555
          Check the voltage on all the output channels, this is usually at the common point of the ceramic emitter resistors of the output transistors or the output to the speakers BEFORE the output protection relay. This offset voltage needs to be close to 0 volts. Upload the service manual
          • stinkincaps
            • May 2020
            • 18
            Service manual attached. What boards do I need to reconnect and power up to check these voltages?
            • R_J
              • 9555
              Which boards do you have disconnected? I would think you need all of them connected. Check the voltages on (page 108) the center of R2249 for the FL channel. or any point on that line that you can access like SCN-SCN 5P and 4P
              You need to check this voltage as soon as you turn on the amp. if you wait the protection circuit will cut in and you will get a false reading. You need to check this voltage on all channels.
              You may need to cancel protection mode (page 28) to work on the amp.
              • stinkincaps
                • May 2020
                • 18
                I took the digital board and Operation(4) board out to get to the output transistors. Once I put the boards back, getting to measure more than 2 of these resistors (C + FL) will be a bit tricky to impossible.
                • R_J
                  • 9555
                  what about the position on page 21, that should allow access to the main board. Don't forget the ground jumper leads.
                  • stinkincaps
                    • May 2020
                    • 18
                    That looks doable. Let me reassemble and pop the back off.
                    • stinkincaps
                      • May 2020
                      • 18
                      All the ceramic resistors are 0V, except R2249, showing -9.8VDC on the 3 legs.
                      • stinkincaps
                        • May 2020
                        • 18
                        Some voltage readings:
                        • R_J
                          • 9555
                          That will be the problem channel, You should be able to compare resistance etc. to a good channel to find the problem. It is only -10v so it might be hard to locate the cause of the offset.
                          • stinkincaps
                            • May 2020
                            • 18
                            Thanks R_J,
                            To confirm, I'll power down and check device resistance & compare to good channel? Looking at everything from resistors, diodes, transistors and caps?
                            • stinkincaps
                              • May 2020
                              • 18
                              Found some components that don't meter like the others. Time to order some parts.
                              • stinkincaps
                                • May 2020
                                • 18
                                Also found C2165 to have lower resistance. This one is a mlyar cap, hard to find. Seems like only NTE has it, so I'll order everything from there, as best they have it.
                                • R_J
                                  • 9555
                                  I doubt the cap C2165 has a problem, they are very reliable. there are many things that can throw off the readings, The meter uses a small voltage to check resistance so ANY stray voltage in the circuit will throw off the reading one way or the other. I would suspect either a resistor that change value (went high in value) or a leaky transistor, which might not show up in a resistance check.
                                  Remember that the OFFSET voltage you measured is -9.8v, which indicates that Q2137 or Q2151 is very slightly biased on a bit more than Q2136 or Q2150. You might need to chack as farback in the circuit as Q2114, Q2121. There are dc voltages given on the schematic, did you check how close they were?
                                  • stinkincaps
                                    • May 2020
                                    • 18
                                    The parts arrived and sat for a few weeks. Finally pulled the unit off the shelf and started pulling parts. C2135 was dead for sure, no capacitance measured. Replaced. I also replaced Q2107 & Q2114.
                                    The rest of the suspect parts I pulled from the board and measured out of circuit, all came in fine.
                                    The unit now powers up fine. I'm getting a 39-40 mV reading on R2249 (all 3 legs are the same). Other resistors are 0.000V. It was -9.8V before, so much better.
                                    Should I be worried about 40mV there? I guess I can start looking at circuit voltages and compare to the schematic.
                                    • stinkincaps
                                      • May 2020
                                      • 18
                                      Voltages measured in protect mode is showing 50mV. (prior measurement showing 40mV was not in protect mode).
                                      I'm not smart enough with analog circuits to figure out where the issue lies.
                                      • petehall347
                                        • Jan 2015
                                        • 4427
                                        • United Kingdom
                                        q21174 q2107 need a matched pair .
                                        • sanalelevenstar
                                          Yamaha RX-V485 Wn9711 Update
                                          by sanalelevenstar
                                          Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                          I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                          I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                          12-04-2024, 04:32 AM
                                        • jjne
                                          Yamaha RX V675 sound issues
                                          by jjne
                                          I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                                          From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                                          At first I thought it was either a speaker relay or the DSP, but I don't think...
                                          06-24-2025, 07:01 AM
                                        • AlexVG
                                          YAMAHA CLP-550 without of sound
                                          by AlexVG
                                          Hi.
                                          I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                                          I have replaced all green marked elements, but it gave me nothing.
                                          The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                                          But it is custom YAMAHA's chip, and I can't find any information about it.
                                          Maybe somebody came across with the same issue?
                                          Any information will be very useful. I will be very appreciated.
                                          Thank you....
                                          06-08-2025, 09:29 AM
                                        • hemant_2222
                                          Yamaha RX-A1020 full dead
                                          by hemant_2222
                                          Hello Everyone,
                                          Greetings!
                                          It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
                                          09-14-2024, 11:25 AM
                                        • sanalelevenstar
                                          My yamaha Rxv-485 showing version error
                                          by sanalelevenstar
                                          My friends Yamaha RXv-485 receiver has stopped communicating on network and Bluetooth, we decided to make a firmware update from USB stick but after a while it comes up with the message "unknown".... Its the latest 1.87 version we are trying to load and it seems like the is no firmware in it at the moment as it does not state the old version ?
                                          Any ideas how to resolve this issue?​
                                          07-31-2024, 07:11 AM
