My yamaha Rxv-485 showing version error
  • sanalelevenstar
    • Jul 2024
    • 9
    • INDIA
    My friends Yamaha RXv-485 receiver has stopped communicating on network and Bluetooth, we decided to make a firmware update from USB stick but after a while it comes up with the message "unknown".... Its the latest 1.87 version we are trying to load and it seems like the is no firmware in it at the moment as it does not state the old version ?
    Any ideas how to resolve this issue?​
  • R_J
    • Jun 2012
    • 9535
    See if this helps
    • sanalelevenstar
      • Jul 2024
      • 9
      • INDIA
      i tried all method usb and network not working...
      • dobrykamil
        • Jun 2013
        • 62
        I know, this thread is regarding different models, but I believe yours also have WN9711 module. Read the pdf file from post 7. Perhaps 485 also have those two solder pads.
        https://www.badcaps.net/forum/troubl...-wn9711-update
        • sanalelevenstar
          • Jul 2024
          • 9
          • INDIA
          my case there is no internal error message ,only version error displaying screen ,amplifier section working perfectly but network,USB and Bluetooth not working
          • sanalelevenstar
            • Jul 2024
            • 9
            • INDIA
            can you share exact location of soldering pin I will share you service manual https://drive.google.com/file/d/13mW...usp=drive_link
            • lotas
              • Jan 2016
              • 4597
              • Russia
              New firmware v1.88.
              https://usa.yamaha.com/support/updat...d485_firm.html
              • sikocan
                Lenovo X1 Carbon 9th Gen Black Screen
                by sikocan
                I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                SN: PF3G1REP
                MODEL: 20KW-00J1AU
                PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                06-24-2025, 09:01 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gerenis
                yamaha rx-v571 firmware, anyone?
                by gerenis
                Anyone got the firmware for yamaha rx-v571? Not available on the internet.
                I've got a defective RX-V571. Could be due to a failed update, but the only function I can invoke is "USB UPDATE".
                Normal power on, Diagnostic mode or Protection Cancel mode don't work.​
                03-01-2025, 08:27 AM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
