Making a Balanced Audio Connection
  • clearchris
    • Dec 2013
    • 687
    I have been wanting to add a balanced line out to my SAE P102 preamp for years. During the rehab of the unit, I found the following in the manual for the SAE P101 preamp (P102 is unobtainable). I believe it means (though it does not directly say this) that I can create a balanced line out by using both MAIN OUT 1 and 2. MAIN OUT 1 is two rca jacks, one red one white. Same with MAIN OUT 2.
    The manual basically says that MAIN OUT 2 is "out of phase (inverted)" with respect to MAIN OUT 1.
    It sounds like I can take the MAIN OUT 1 "right" jack tip as "hot" in my balanced connection, take the MAIN OUT 2 "right" jack tip as "cold", join both grounds, and that's the three wires for my balanced XLR connection. Same for both "left" channels. Or is there something more to this? The rest of my rack (crossover and amps) are all balanced connections.
    Here's the whole excerpt from the manual:
    I'm hoping this infernal humming coming from my system. The preamp sounded so good on my bench, and now it's so clear, the hum when I put it in my rack is super annoying.
    Thanks!
    Re: Making a Balanced Audio Connection
    The hum may be due to Ground loop issue.
      P101: Yes you can create Balance output using Main out 1 CH A (called it +) and Main out 2 CHA (called it -) as Balanced output for Ch A, same is applied to CH B.
      But does P102 has the same output configuration?
      • clearchris
        • Dec 2013
        • 687
        They are pretty similar units. The would be absolutely terrible people if they used the same nomenclature between adjacent product versions and changed the features. I suppose it's time to buy that cheap and cheesy oscilloscope and verify before I blow up the preamp.
        About the grounding, I have an older house that doesn't have 3 prong plugs. So my stereo rack has one of those adapters with the screw, and I dutifully screwed it into the outlet, but I know there's just two conductor plastic coated cable behind the outlet, so there's no real grounding. I don't have cable tv, so there's no ground there. I do have an ethernet line running from my rack to the wiring closet, but I'm going to take out the hub (for testing) and directly connect to the flatscreen. The flatscreen is connected to the preamp via fiber optic cable and a converter box.
        It's really annoying, I can't hear the hum now, it comes and goes apparently. Swapping cables, etc, sometimes works, sometimes doesn't. It's quite a pain to track down.
        Just noticed my amps have a "ground lift" switch, I'll try that too.
          The ground lift switch on the Amp is to let you isolate the Amp circuit ground from safety ground.
          To track the hum problem is start with just connecting power amp amp speakers first then start adding additional component one at a time and listen for the hum.
          • clearchris
            • Dec 2013
            • 687
            Well, if that's the case, there's no hum when I take my crossover out. To do that, I have to use unbalanced cables from the preamp to the amp. So it's not an exact test, and why I figured I'd see if I could build a balanced cable from the preamp to the crossover, I could also use that same cable to go direct to the amps. It actually sounded really good with no crossover, but no subwoofer.
            If it is the crossover, I can't really isolate that can I?
            • clearchris
              • Dec 2013
              • 687
              Budm: You were right again. I checked the schematic, and I'm 80% sure there's no difference between the two outputs on the P102. I'll have to double check the next time I open it up, but I'm not expecting to be pleasantly surprised. Ah well, back to the drawing board.
              • clearchris
                • Dec 2013
                • 687
                I picked up an aphex 124a unbalanced to balanced converter and the buzzing is gone and the system sounds much better. I was going to build a converter, but I picked up the 124a for around $30 and I couldn't compete with that.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
                • mkdj
                  Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                  by mkdj
                  Dear all,
                  I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                  I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                  Both N-Channel Mosfets: nothing odd
                  P-Channel MOSFET number 1:
                  source - drain : 117 kOhm
                  source - gate: 96 Ohm
                  gate - drain: 117 kOhm
                  P-Channel MOSFET...
                  08-20-2025, 06:08 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
