Yamaha RX-V596RDS goes off immediately upon start
  • .vince
    • Apr 2020
    • France
    I have this RX-V596RDS that won't work.
    I press the "Stand-by/ON" Button, the relay clicks, the screen is powered and within 2 tenth of a second, the relay clicks again and the screen goes off.
    I have the service manual here :
    (it shows that this unit is commun with RX-V596 and HTR-5250)
    I can not access the "Self Diagnosis Function".
    Before I dig into the schematics, does this ring a bell to anybody ?
    Thanks,
    .vince
  • wazzadj@hotmail.com
    Wazza
    • Nov 2017
    • 57
    Re: Yamaha RX-V596RDS goes off immediately upon start
    Output transistor has a fault
    • Rensiee
      Panasonic TH-50PX8EA Black screen, only relay clicks
      by Rensiee
      I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
      I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
      When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
      I have measured the voltage in the VSUS line, which...
      06-18-2024, 12:58 PM
      Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
      by momaka
      I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
      Problem:
      Backlight cycles On and Off.
      Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
      01-17-2019, 11:23 PM
    • samtron786
      toshiba 46xv555d relay clicks
      by samtron786
      Hello
      The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
      2-3 seconds later the relay will click again and only the red LED will stay on.
      I would be very grateful for any advice or a little help.
      circuit diagram?
      Thanks very much
      02-04-2023, 04:39 PM
    • jjne
      Yamaha RX V675 sound issues
      by jjne
      I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
      From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
      At first I thought it was either a speaker relay or the DSP, but I don't think...
      06-24-2025, 07:01 AM
    • redbaron1007
      Yamaha HTR-3065 No power/No Standby
      by redbaron1007
      I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
      S9 13.7V
      Pwr Ry 0V
      AC Det 9.1V
      Mgnd 0V GND
      The two pins on the transformer for the operation...
      09-12-2024, 03:04 PM
