LG Xboom PK5 demo mode..probably
This topic has been answered.
Re: LG Xboom PK5 demo mode..probably
I work for a major retailer which has the demo units for the PK7, PK5, and PK3. If you look at the bottom of the unit you will see SVC CODE: PK3.AUSDEMO
These are firmware modified units from LG which will disables all controls other than "Enhanced Bass", prohibits Bluetooth, and battery operation. I the only way I have seen people overcome these firmware locks in the past is to open a retail unit, dump the firmware, open the demo unit and overwrite the NAND with retail firmware.Comment
I also purchased 2 demo units of PK3 but haven't figured out a way to turn demo mode off.
PK3 has a different motherboard design inside. PK5 and PK7 have 64 bit SPI rom chip inside but PK3 don't.
would be good to use them if possibleComment
Nice work tomodachi!
Good to see more useful things getting saved from the dump. Proof that manufacturers don't give half a sh** about the environment and only care to fill up their pockets.
Also, thank you for sharing the firmware here. I'm sure other people will find it useful as more of these demo units are uncovered.Comment
Hey, I m here again with the solution !
Finally found a retail version of PK5 and backed up firmware from it.
did exactly as rcdavi3 mentioned here and result was just as expected.
after reflash unit will work same as retail version.
I m posting here the dump, its ok but belong to an older version.
after reflash unit will work same as its retail version.
Remember to update firmware after reflash, not only will update software, it will also increase volume to about %20
To update firmware you need to install an app to your phone named "LG Xboom"
any questions let me know
Models that work with this dump;
LG Xboom PK5
LG Xboom PK7Comment
also looking to find out the steps to push the firmware file onto a demo speaker. is there a method that uses the usb port that can do this, or do you physically have to remove some soldered chip from the circuit board or something like that? the image posted above is for a device that costs $45 on amazon, so its not worth it if that's the case. there's no real direction here on what to do.Comment
you will have to remove the SPI chip from the circuit board and program it with the binary file that I shared here.Comment
Hey New to this site. Glad I came across it so as I have a demo unit pk7. By chance do you remember which chip is the bios chip on the board? And what flasher did you use?
Hope to hear from you soon. Thanks!Comment
Hi to all, I'm new on forum;-)
Have PK7 demo and read your solution- please could you explain wiring and programmer used? Suppose FTDI or similar?
Thx in advance;-)Comment
Sorry, now I see that you already explained above all my doubts.
Thank you for solution;-)Comment
Hi, I have a couple of LG XBoom PN7 speakers, one of which was stuck in what I now know was demo mode, only works when plugged in, power button doesnt work, stuck at max volume and no BT. After scratching my head for a while I chanced upon the firmware file for the PK5 from here.
I took the demo speaker apart and found the firmware chip, unfortunately it was only a 1Mb chip, so the PK5 firmware could not be flashed to it. I took the chip off of the board and put it in my CH341A programmer and read the hex from it. I really didn't want to, but I took apart my new fully working speaker, and took the chip from that board. However, upon reading that, it was completely empty with every value was FF. I didn't know whether I had fried the chip or somehow wiped it, and was calling myself a stupid whatever. Anyway, I put the chip back on the board and put it back into the speaker. It powered up perfectly!
So now, with nothing to lose, I put the old chip into the programmer, read the data, saved it, then thought "what the hell" and clicked "Erase". It wiped all values to FF on the chip, I took the now "empty" chip and soldered it back onto the board, put it back together enough to test, and voila, a fully working speaker, works on bluetooth, connects together for dual play.
So if you happen to see one advertised as having "Charging Issues" with the same symptoms as mine, you can easily repair it by merely wiping the chip.
Tldr. If you have a PN7 stuck in demo mode, take the chip off and erase all data from it.Comment
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
by JohndillHi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
Here are the tested scenarios:
1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
2. With the laptop off, plug in charger (LED says on) & the front charging... -
by karthurOn this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related.... - Loading...
