Confusion about replacement HDMI port
  • ajvpb
    • Apr 2019
    • 13
    Hi guys, apologies for the noob question. I have a Denon AVR-920S with a bad hdmi output port. Looks like the prior owner tried forcing it in when the alignment was off, it pushed the plastic center piece back and broke some of the connections to the board.
    My struggle is in finding a replacement. The receiver supports hdmi 2.0a/hdcp 2.2. When I search digikey they only spec compliant ports they list are 1.4. I vaguely remember reading something about a licensing dispute, so that could be it. I understand hdmi 2.0 is a hardware upgrade from 1.4. Are all of those hardware changes after the signal gets to the port? Or put another way, does the connector version not matter?
    Alex
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Confusion about replacement HDMI port
    No, the port doesn't matter, it's the signal, cable and hardware to decode that change.
    • ajvpb
      • Apr 2019
      • 13
      Thanks for the confirmation!
      • RossMoodley1967
        LG LCD TV HDMI PORT FAULTY
        by RossMoodley1967
        LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
        02-28-2024, 08:38 AM
      • pansatdishman
        lg 60pa6500 hdmi port replacement
        by pansatdishman
        hello all i have a lg 60pa6500 trying to find a replacement hdmi port i ordered some but the legs dont line up as there not symmetrical thanks
        01-06-2023, 08:38 PM
      • SuperAman
        PS5 HDMI port diode reading?
        by SuperAman
        I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
        02-03-2024, 10:16 PM
      • amuse619
        Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
        by amuse619
        Hello!
        Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
        Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
        08-14-2024, 01:22 PM
      • Nikolai Danylchyk
        Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
        by Nikolai Danylchyk
        Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
        Thanks in advance!...
        05-08-2025, 06:18 AM
