Onkyo TX-SR507 stuck in standby mode/protection mode, relay clicks one time
  • waterboy1602
    • Jun 2019
    • 14
    • Belgium
    I would be really happy if someone could help me with this problem. I'm already trying for longer then a year with on and offs to fix this problem.
    I have an Onkyo TX- SR507 (schematics added) that is stuck in standby mode. The red light is on if I connect it to the net. When I press the power button I hear a relay clicking. The relay clicks just for one time and then the red light goes back on.
    I had a blown capacitor (C6040)and shorted transistors (Q6050, Q6060) at one channel from the receiver. I replaced R6100, Q6050, Q6060 and C6040. Is there something I missed? Or could someone help me with this problem?
    Thank you!!
  • R_J
    • Jun 2012
    • 9594
    Re: Onkyo TX-SR507 stuck in standby mode/protection mode, relay clicks one time
    Did you also check the resistors in that area? R6070,6080,6090,6100, also check for DC on the center of R6100 at first turn on, there should be close to 0 volts.
    • waterboy1602
      • Jun 2019
      • 14
      • Belgium
      I checked them all. Only R6070 was shorted. I already had replaced R6100. So now I also replaced R6070 and tried to start it. I pressed the power button (with the back cover not installed) and the R6070 resister exploded directly.
      What could be the reason for that?
      • R_J
        • Jun 2012
        • 9594
        What do you mean R6070 was shorted? resistors don't go shorted, they go open, I suspect you are not checking components properly and there are a lot of defective parts in that section of the amp.
        You need to check every transistor and resistor in that section, If R6070 opened it is because Q6040 or Q6030 is likely shorted or biased on hard by one of the drivers connected to its base.
        Re check Q6050 & Q6060, they could also be damaged again, also check R5180 & R5190. You may also want to check Q6070, it may have been damaged when the outputs shorted
        To blow C6040 or R6070 would require a high voltage across them (100v?) under normal conditions there is only about 1.2 volts across those components
        As an example if Q6040 and Q6030 were both turned on at the same time you would have aprox. 105 volts across a 50v cap and that poor 100Ω .25w would explode
        Compare your resistance readings on this bad channel to a good channel, that can help find bad components
        • waterboy1602
          • Jun 2019
          • 14
          • Belgium
          Fixed the problem. It was my fault. I didn't checked some transistors that were broken. Replaced them now. When I now try to start I hear a relay constantly clicking around the poweramp. It clicks almost every half a second. What could be the reason for that?
          Thank you already for all your help!
          • R_J
            • Jun 2012
            • 9594
            There is likely still a problem and there is still a voltage on the output causing the protection to engage. there must be close to 0 volts on the output going to the speakers, if there is a volt or two that will cause the relay to trip out to protect the speaker from the DCvoltage
            Which other parts were bad? knowing what parts were defective might help in solving the problem.
            Also did you do the idle adjustment after replacing the parts? that may be all that is needed
            • petehall347
              • Jan 2015
              • 4440
              monitor amp out dc voltage before relay .
              • waterboy1602
                • Jun 2019
                • 14
                • Belgium
                I had to replace Q6010, Q6030, Q6040, Q6050, Q6060 and R6070. What do you mean with idle adjustment? I don't know what that means.
                • R_J
                  • Jun 2012
                  • 9594
                  See that adjustment on the base of Q6010, Is the pot there? connect volt meter across P6080
                  See page 21, bottom right:
                  Did you check the voltage on the center point of R6100 yet? If that voltage is off the amp will go into protection.
                  • waterboy1602
                    • Jun 2019
                    • 14
                    • Belgium
                    I adjusted them to the right values, but the relay stays clicking. All the pot values were around 1mV and I had to change them to 9-11mV. I also checked the voltage at R6100 and got a value around 0.6mV. Any reason for that?
                    • R_J
                      • Jun 2012
                      • 9594
                      That 0.6 volts is what you should read at R6100, and all the other channels at that point.
                      Since there are a lot of relays (10~12) in this amp, which relay is clicking?
                      • waterboy1602
                        • Jun 2019
                        • 14
                        • Belgium
                        It's not clear which relay that is clicking, but I'm pretty sure that it's RL901 from the power supply board.
                        • R_J
                          • Jun 2012
                          • 9594
                          If that is the relay that is clicking, it could be due to a weak +12 volts, C922 could be bad. That is the main power relay, if it is turning off the whole amp will turn off, is that what is happening?
                          Check the POWERD line and see if it is changing
                          • waterboy1602
                            • Jun 2019
                            • 14
                            • Belgium
                            The POWERD line goes after every click back to zero. Before the click it's 10V. What doest that mean?
                            • R_J
                              • Jun 2012
                              • 9594
                              Whats the voltage on C922?
                              How were you able to adjust the idle current if the amp keeps turning on and off?
                              • petehall347
                                • Jan 2015
                                • 4440
                                is unit powered by full mains ?
                                • waterboy1602
                                  • Jun 2019
                                  • 14
                                  • Belgium
                                  The voltage at C922 goes at about 10/11 volts and fluctuates then after every click. It goes almost back to zero after every click.
                                  There is still some voltage to the amps before it turns off and i changed the idle current to that voltage.
                                  • waterboy1602
                                    • Jun 2019
                                    • 14
                                    • Belgium
                                    What do you mean with that?
                                    • R_J
                                      • Jun 2012
                                      • 9594
                                      Are you telling me the voltage on C922 drops to 0 volts? then you have a problem with the standby circuit I suspect C922 is completely open or the diodes are failing or R921 is going open or has a poor solder connection
                                      I would also check the +10VS and the POFF volage on JL901a. This 10 volts supplies the 5 volt regulator ic for the cpu
                                      • waterboy1602
                                        • Jun 2019
                                        • 14
                                        • Belgium
                                        No, C922 drops from 11V to something around 9V. R921 is alright. I checked +10VS: it fluctuates between every click from 10V to 8.35V. POFF: from 4.77V tot 3.25V with every click.
                                        • Rensiee
                                          Panasonic TH-50PX8EA Black screen, only relay clicks
                                          by Rensiee
                                          I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                          I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                          When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                          I have measured the voltage in the VSUS line, which...
                                          06-18-2024, 12:58 PM
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • toty79
                                          Hisense LTDN50K220WSEU stuck in standby
                                          by toty79
                                          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                          As per Hisense tv title LTDN50K220WSEU stuck in standby
                                          PSU rsag.820.5687 HLL 4855WF
                                          Main rsag 7.820.5842
                                          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                          05-01-2022, 04:39 PM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
