Another Yamaha
  • R_J
    • 9535
    Re: Another Yamaha
    The standby led supply voltage is the +3.3M It can be tested on operation board plug CB473 (page 136) There is also the control line from the main microprocessor ic which is the pin next to it, it should change when the amp goes from operate to standby
    • No1baggiesfan
      • Jan 2019
      • 45
      • England
      #62
      Re: Another Yamaha
      I'll test that tomorrow, but for now it seems to be ok, it's working at least.
      One other issue I noticed is that when I press 'sur decode' it goes into 'straight' mode when it should go into 'neo' mode
      • R_J
        • 9535
        Re: Another Yamaha
        Try doing a full reset, if that does'nt help check the firmware version, I see there is a firmware update to ver. 1.80
        • No1baggiesfan
          • Jan 2019
          • 45
          • England
          #64
          Re: Another Yamaha
          Firmware is already 1.80
          Just turned the amp off, red standby light is now on lol ??
          • R_J
            • 9535
            Re: Another Yamaha
            Thats likely how it works, standby led lit in standby, turns off when amp is on.
            • No1baggiesfan
              • Jan 2019
              • 45
              • England
              #66
              Re: Another Yamaha
              It does, but it it hadn't lit since last week
              • No1baggiesfan
                • Jan 2019
                • 45
                • England
                #67
                Re: Another Yamaha
                Update.
                Looks like she's back to her old self again, everything is working as it should, watched a couple of movies, no issues, does seem to be a tad warmer than I remember, maybe it's just me being paranoid lol.
                Anyway, want to say thank you again to R_J for his time and help and everyone else who also joined in.
                • No1baggiesfan
                  • Jan 2019
                  • 45
                  • England
                  #68
                  Re: Another Yamaha
                  Update again.
                  Amp still working, yay
                  Now I need to fix the on/off button on the remote, :/
                    Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                    Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                    various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                    Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                    trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                    what is wrong with your PC in just seconds. It saves you time and money.
                    Our new and improved design...
                    11-01-2024, 06:29 AM
                  • Sinnyone
                    Yamaha RX-V3900 dim display and turns off
                    by Sinnyone
                    This is a repost since I never completed this fix. I just left it, but now the receiver powers off into safe mode and does not complete the Self-Diagnostic when i start with those buttons pushed. It says it is, but does not do the diagnostics and does not show any faults or that it has none, which it should do. So here i am again. The previous post did have a schematic but I think it was cut off somewhere. I do not know what board it is referring to. Any help would be appreciated.
                    I have searched through the forums and have not found anything about my problem. So,...
                    08-30-2023, 08:35 AM
                  • nzphil
                    Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
                    by nzphil
                    I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
                    04-11-2021, 05:58 PM
                  • sanalelevenstar
                    Yamaha RX-V485 Wn9711 Update
                    by sanalelevenstar
                    Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                    I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                    I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                    12-04-2024, 04:32 AM
                  • jjne
                    Yamaha RX V675 sound issues
                    by jjne
                    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                    At first I thought it was either a speaker relay or the DSP, but I don't think...
                    06-24-2025, 07:01 AM
