canton dm55
  • mesta83
    • Nov 2015
    • 75
    • merseyside
    canton dm55
    hi guys does any one have an idea about canton dm55 it tuck on boot loop i did change d2d chip but still doing the same , if any one have any idea , thanks .
    • 22293
    Re: canton dm55
    There`s a video on youtube about the boot loop, it might help . https://www.youtube.com/watch?v=_fl_dwOaVlw
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • Takeatry
      Yet another Samsung QLED Boot Loop
      by Takeatry
      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
      10-04-2024, 02:57 PM
    • blaster_
      Samsung UE49MU6105K - boot loop, horizontal lines
      by blaster_
      Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
      Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
      06-22-2022, 05:19 PM
    • torchzack
      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
      by torchzack
      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
      08-28-2023, 07:42 AM
    • No Lan
      [Macbook pro A1708] [Boot loop] [Trackpad ?]
      by No Lan
      Hey everyone,
      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
      05-24-2025, 03:09 PM
