HSU Research VTF-2 MK1 subwoofer amplifier repair
  • taligent
    • Jan 2017
    • 8
    • US
    Symptoms: Sub powers on and has good power rail voltages and +/- 15v rails, but does not output sound.
    Troubleshooting: The area around IC104 (a 7815 voltage regulator) on the amp board shows signs of heating (burnt PCB) but the regulator itself seems to check out. This was a good opportunity to test out a newly delivered AVR transistor tester - the capacitance and ESR testing showed that nearly all of the Jamicon electrolytic caps on the amplifier board had issues with capacitance value or ESR.
    The capacitors near the 7815 regulator showed nearly zero capacitance (likely dried out), while the remaining capacitors were off by 50-75% and some had ESR over 50 ohms. I replaced all but the large power supply caps:
    • C132: 47uF 16v
    • C133: 10uF 50v
    • C139: 100uF 16v
    • C141: 100uF 16v
    • C501: 2.2uF 50v
    • C502: 1uF 50v
    • C503: 47uF 16v
    • C506 10uF 50v
    • C508: 10uF 50v
    Result: Success! The amp fired up and showed good output - all that remains is a scratchy gain pot. This was a free sub so for now the replacement capacitors are from the scavenged parts pile of older Nichicons and Elna caps.
    Hope this helps anyone running into a similar issue!
  • CapLeaker
    Leaking Member
    • 8188
    Re: HSU Research VTF-2 MK1 subwoofer amplifier repair
    Nice repair. Usually those little caps always take a beating, specially those near a heat sink.
      the -15V power supply has the 1K power resistor is close to the bridge rectifier but still close to a small cap, the 1K for the +15 is right next to the regulator and caps, when you dropping +/-40V or so down to +/-15V, the heat will have to go some where.
      Those two resistors do get quite hot and since the board is basically sit in and air tight enclosure so it has poor thermal management which is bad for caps, but that is typical design for these subwoofer, they made them to last for a little while.
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        i dont know who decides where the hot parts go in relation to the ones that want to stay cool is but they should be looking at getting a different job if they care about the product rather than sales .
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Awesome, great to hear you got it going!
          From my limited experience with amps, it seems that a lot of late 90's and 2000's stuff has cheap caps that just go bad after 5-10 years in service. So I am not surprised you found so many bad ones, especially given the poor thermal design.
          If I had to guess, probably no one at the company gave two sh**s about the product lasting. They just wanted it out the door and selling to bring in $$. Just looking at the whole PCB layout makes me cringe. A lot of 90's and 2000's (and onwards) amps are made like this - at least the cheaper models anyways.
          As NewEgg products often say about cheap stuff:
          "Pros: Product works great!
          Cons: Didn't last long"
          • mabrow
            • Jul 2020
            • C132: 47uF 16v
            • C133: 10uF 50v
            • C139: 100uF 16v
            • C141: 100uF 16v
            • C501: 2.2uF 50v
            • C502: 1uF 50v
            • C503: 47uF 16v
            • C506 10uF 50v
            • C508: 10uF 50v
            Hi All,
            I recently purchased a used HSU VTF-3 MK2 for cheap. Upfront I knew there was no audio output. Power off/on lights work and good fuse, just no sound.
            Is this sounding like cap issues to those out there that have dealt with this?
            I saw Taligent's post on cap replacement and I'm trying to source new caps. Anyone know a good source for caps?
            Thanks!
            • vestaviascott
              • Aug 2018
              • 100
              Ditto. I picked up a thrift store find HSU VTF-3 MK2. No audio output, but power light front (logo) and back green auto power LED light up. I hooked high line input left and right and got no sound. Immediately felt heat from the bottom right section of the plate. Took the plate off and found that the heat appears to be coming from one of the 15v voltage regulators.
              Not sure how to proceed. Just replace these two or should I test them and move to capacitors like OP? Don't want to risk further damage due to how much heat I'm getting when the unit is powered on.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                In the USA:
                Digikey.com
                Mouser.com
                https://www.badcaps.net/store/
                Try replace the caps near those regulators first. Chances are they may be dried up and making the regulators not able to regulate properly anymore.
                Depending on your expertise and test equipment, you can also check the regulators out of circuit by building a test circuit, or you can just simply replace them with new parts (these are standard +/-15V regulators, so shouldn't be hard to find.)
                If new regulators still overheat, there may be something else wrong with the amp downstream that is pulling too much current and causing the regulator(s) to overheat.
                Generally, the 78xx and 79xx linear regulators are thermally protected, so they shouldn't burn out even if overloaded.
                • vestaviascott
                  • Aug 2018
                  • 100
                  Originally posted by momaka
                  In the USA:
                  Digikey.com
                  Mouser.com
                  OK, thanks very much for the information. The 15v regulators actually just arrived from mouser, I ordered both positive and negative. I don't have any replacement caps or an ESR to test them. I suppose I'll go ahead and replace the regulators and see what she does.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Sounds good. Keep us posted how it goes.
                    Given how close those small caps are by the regulators, I wouldn't be surprised if they are dry already (and part of the problem.)
                    Instead of moving the caps or the regulators, one can also just use better caps. From the pictures above, it seems like those are regular 85C GP caps. 105C entry-level low ESR from the good Japanese brands will probably last much longer. Something like Panasonic FC, Nichicon PW / PM / PS / PJ, Rubycon YXJ, or Chemicon LXZ / KY should all work well.
                    • jinu_j
                      How to test Subwoofer Amplifier with only a multimeter
                      by jinu_j
                      Hi Folks
                      Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                      Problem
                      I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                      Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                      Any advice would be appreciated...
                      08-29-2024, 02:05 AM
                      Acer Predator PT315-51-7815 Notebook Specification for Upgrade or Repair
                      This specification for the Acer Predator PT315-51-7815 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT315-51-7815 boardview and PT315-51-7815 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 11:44 AM
                      Acer Predator PH317-51-7815+Helmet VR Notebook Helios 300 Specification for Upgrade or Repair
                      This specification for the Acer Predator PH317-51-7815+Helmet VR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-7815+Helmet VR boardview and PH317-51-7815+Helmet VR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 06:45 AM
                    • rustinjust
                      Please help, subwoofer connected to tv, read description below
                      by rustinjust
                      I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                      Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there a way of...
                      10-28-2023, 07:09 AM
                    • rustinjust
                      Please help, where can I get a remote for my subwoofer?
                      by rustinjust
                      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there...
                      10-28-2023, 03:43 AM
