Onkyo A-8250 50V on DC Offset transistor
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Can anybody help me identify the problem with my Onkyo A-8250? Instead of ~1.5V on Q517 offset transistor I am getting 50V.
    I have replaced: Q511, Q513, Q517 (Was defective), Q515, D507, D509, D513, D515. (Diodes with 1N4148, transistors with exact models)
    Also checked C601, 603, 509, 507 (all good), R523, R535, R529, R533, R527, R525, R537 (all good), and the front and back from there transistors. It is illogical to me why I am I getting 50V on Q517. On the other channel it is normal ~1.5V as it should be. With out Q515 i get ~3V, but Ive replaced it 3 times already, and all of them measure correctly. This is measure with the amplifier section transistors removed (as they all go up in flames due to this).
  • redwire
    • 3910
    Re: Onkyo A-8250 50V on DC Offset transistor
    It's not making sense.
    Q515 is a constant-current source, it should pull down the Q517 point to just below zero volts. Removing Q515 should not lower the 50V down to 3V, there is no path for that unless the diode string D505/D507/R527/D509/D511 has a problem. In a series diode string, if there was an overload, it doesn't make sense to replace D507 but not D505 etc.
    I would suspect the next (driver) stage, because if Q517 had failed, then the output/driver transistors must have shorted. R603, R601 can get cooked too, they are usually flameproof/fusible.
    What I'd do is diode-test every semiconductor, and compare to the other channel. You still have a bad component. It just takes patience and less smoke doing this for 15 minutes.
    The current through R525 and R523 should be almost equal, unless the driver stage has a problem. You can measure the voltage across them and use ohms law, assuming the resistors have not been damaged.
      BTW, Q517 is part of the active bias circuit.
      • Sojke
        • Apr 2017
        • 131
        • Serbia
        Replaced D511 and D505 with same forward voltage red diodes 1.93V (only lesser capacitance 15pF instead of D511 44pF, D505 29pF), nothing changed.
        Ive noticed that when powered on, D511 blinks and turns off, D505 continues to glow. When power is turned off after some time D505 turns off and D511 turns on, than after a shorter period of time it switches again D505 on D511 off. R525 564ohm , R523 6.89ohm and R550 44.36k ohm.
        I have removed the transistors and resistors in the Amplifier section as they have all burned , even tried removing C603, C601 and C507. I have no idea where is the voltage escaping. (Its weird)
        • Sojke
          • Apr 2017
          • 131
          • Serbia
          (Sorry if double posting is not allowed but I cant edit the previous message any more)
          Solved. Amplifier transistors are necessary to be mounted in circuit in order for bias circuit to work properly.
          • electricboyo
            • Mar 2013
            • 26
            When an output transistor has failed I temporarily remove all of the main output transistors from the faulty channel. By this I am referring to the large output transistors bolted to the heat sink. Then I connect a 100 ohm 2 watt resistor from B to E terminal pads for each spot on the PC board where an output transistor was originally connected. Do not connect anything to the C terminal pads on PC board. The 100 ohm resistors provide the continuity that is required to get the rest of the amplifier circuit working. And it should be possible to get enough audio output to hear something from the headphone jack.
            When the rest of the amplifier circuit is working correctly there will be about 0.5 to 0.6 of DC voltage drop across each of the temporary 100 ohm resistors. And the speaker protectin relay should click in. DC voltage from either end of the temporary 100 ohm resistors should be < 1 volt in reference to negative black speaker terminal output post. This is circuit ground (earth) in most cases.
            EB
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              i use 1k resistors to complete the feedback circuit if they are needed . most times the drivers emitter resistors do this job anyway .. never had a problem with 1/4w resistors . no load at speaker terminals .
              • electricboyo
                • Mar 2013
                • 26
                This model and some other Onkyo amplifiers have an unusual architecture for the output stage.
                There are 3 low value emitter resistors connected to the output transistors. One or more of these often fail open-circuit after an output transistor shorts out. These resistors are both “flameproof” and “fusible.” They rarely show any visible signs of overheating. Because these 3 resistors are in a series-parallel arrangement it is necessary to disconnect one end of at least one of these 3 resistors in order to check that each individual resistor still has the correct resistance value.
                In this circuit the 2 temporary 100 ohm E to B resistors must be connected in place of the 2 large output transistors to test the functionality of the driver circuitry prior to reinstalling new output transistors. This is necessary because the pre-driver and driver stages have no connection to the output line.
                EB
                • tt34
                  • Oct 2019
                  • Belarus
                  Hi all and Sojke. I have a similar problem with Onkyo a8270. 50v at Q517 transistor. Everything around is working properly. How did you solve the problem?
                  • Sojke
                    • Apr 2017
                    • 131
                    • Serbia
                    Originally posted by electricboyo
                    ... In this circuit the 2 temporary 100 ohm E to B resistors must be connected in place of the 2 large output transistors to test the functionality of the driver circuitry prior to reinstalling new output transistors. This is necessary because the pre-driver and driver stages have no connection to the output line.
                    Exactly this. I had ti replace every transistor from BIAS to Output , with resistors , as it kept burning. Also replaced the double diode with 2x1N4148. So far, a year and so after, the amplifier works or at least i believe it is so as the person whos it is did not report it breaking.
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      that sounds like the bias tracking diodes
                      • jjne
                        Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
                        by jjne
                        I have a TX NR414, well I have two actually which are both exhibiting the same issue.
                        The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
                        I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years...
                        07-28-2025, 07:51 AM
                      • CDNBrewer
                        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                        by CDNBrewer
                        Hello Everyone,
                        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                        Symptoms:
                        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                        • I swapped the Left and Right surround
                        08-05-2025, 09:29 PM
                      • magneh
                        Behringer Eurolive B205D repair - help identifying transistor
                        by magneh
                        Hello
                        Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                        Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                        After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                        I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                        Still, I need to replace this transistor....
                        06-18-2025, 02:34 AM
                      • FrancescoV
                        Onkyo HT-R390 no sound output, video output ok
                        by FrancescoV
                        Good morning everyone,
                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                        The firmware reported is the following:
                        M:1.00/11107BLP
                        D:?.??/????????
                        O:1.00/11107AL
                        The DSP firmware given the question marks seems corrupt.
                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                        05-11-2025, 02:59 AM
                      • elsomer
                        help to identify transistor msi ms-15ck1
                        by elsomer
                        hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                        02-17-2025, 05:30 PM
