USB-B Female 11 pin, input connector for Apogee Quartet
  • elektronikrep
    • Dec 2017
    • Denmark
    Hi Badcaps!
    I've been looking for at replacement USB input for my apogee quartet.
    The device fell to the floor and damaged the USB input, ill try with a repair first, before buying new.
    As i can tell its not a standard 5 pin, but this has 11 pins. (something to do with HDMI also being available here)
    Anyone has an idea where i might find this connector.?
    http://www.apogeedigital.com/product...specifications
    my closest hit is this :
    http://www.globalsources.com/gsol/I/...htm#1046892058
    Best Anders
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: USB-B Female 11 pin, input connector for Apogee Quartet
    <insert bad words here> "custom" connectors and cables...
    I'm pretty sure that asking their support staff / service department for information like that will only result in "send it in, and we'll repair it for several hundred dollars", right?
    But then again, that's still worth a shot, i guess.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Tomylee
      No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
      by Tomylee
      Sorry for the person who’s going to read all this !
      I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
      While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
      During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
      07-11-2025, 11:52 AM
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
    • 5mall5nail5
      Help identifying connector for ASUS 4090 Strix RGB LED connector
      by 5mall5nail5
      Hi All -
      I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
      Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
      05-04-2025, 07:47 AM
    • michhak
      Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
      by michhak
      Hi guys,
      i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
      It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
      11-17-2021, 05:45 AM
    • m1ch43lzm
      70mai Dash Cam A510 - help identifying connector on camera module
      by m1ch43lzm
      Hi everyone
      I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
      The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
      I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
      05-11-2025, 06:02 PM
