Kenwood DNN991 Reset sofware
  • mendezjonathan
    • May 2018
    • 6
    • venezuela
    Hi, I have a Kenwood Model DNN991 unit, I bought it from EBay but it has an entry password.
    Is there a way to restart the software?
    and leave it from the factory?
    I have heard that placing a master password can .. can you help me?
  • R_J
    • 9526
    Re: Kenwood DNN991 Reset sofware
    Does this:
    https://manual.kenwood.com/ce/im383/...hooting-2.html
    or this help
    http://manual.kenwood.com/ce/im383/N...foreUse-2.html
    • mendezjonathan
      • May 2018
      • 6
      • venezuela
      714/5000
      thank you for attending my request,
      the problem is the following I can not enter the operating system,
      I have done the reset for the red triangle but the unit continues entering the menu of the photos ...
      the person who sold me the unit told me the password of the user "batking" and with this user and password I enter the "route collector" page, but I can not access the system of the unit ..
      It tells me that the password is incorrect or the service is not active.
      I have asked the Kenwood service and they tell me that I must take the unit to the technical service so that with a code they can restart the unit.
      Is it possible to access the system in another way?
      Do you have another way of hard reset?
      • R_J
        • 9526
        Have you tried the guest account?
        Someone else had this problem https://www.justanswer.com/car-elect...1hd-model.html
        It likely won't help but have a look
        • mendezjonathan
          • May 2018
          • 6
          • venezuela
          ok thanks for the information I will try to look to see if I solve my problem
          • tibimakai
            • Jan 2012
            • 3680
            I was thinking about your issue, and I think that you should go to the Route Collector site, and sign up there, than use your credentials to log into the Kenwood.
            • shouri
              Dell latitude e5490 auto restart
              by shouri
              Hi guys, can someone help me?
              I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
              Board model is dm70 la-f401p rev:1.0 2017-09-20.
              At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
              After a few days test, is seems ok.
              Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
              12-10-2024, 09:27 PM
            • ngml
              Repair of an LG split AC system indoor unit PCB
              by ngml
              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
              This indicates an error in the communication between the outdoor and the indoor unit.
              The outdoor unit is fine, so the problem is the indoor PCB.
              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
              Does anybody have the schematics of this board,...
              02-01-2025, 12:55 PM
            • Fam787
              HELP! A1398 Dead,
              by Fam787
              I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
              Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
              12-27-2024, 05:19 PM
            • odie34
              Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
              by odie34
              I am a hobbyist (not a professional) so please be gentle...
              I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
              I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
              02-18-2024, 09:11 AM
            • madan1
              Unbricking Vigor AP
              by madan1
              Good day.
              I'm posting this to help other people.
              If you have a Vigor AP with some kind of a software issue or just with an unknown admin password and disabled reset button, here is how you can flash a fresh firmware.
              Download the firmware from the vigor's website and extract it somewhere.
              Download TFTPD64 or other tftp client with file push.
              Connect to the unit with an ethernet cable and set your client IP address to 192.168.1.10 (just not .1 or .2).
              Start TFTPD64, go to tftp client tab. Select the server interface with the above IP and...
              06-18-2025, 02:32 PM
