Yamaha RXV 465 no display and power problem
  • manfriend
    • Jun 2018
    • 10
    Re: Yamaha RXV 465 no display and power problem
    Also, let me apologize for butting in on another discussion. I just saw a thread on a Yamaha receiver and thought this would be a good place to make an inquiry. Thanks.
    • R_J
      • 9588
      Normally its best to start your own thread, but anyway, what is wrong with the relay?
      Digikey Z5885-ND, Omron G5RL-1A-E-TV8 DC5 might be what you are looking for.
      • R_J
        • 9588
        Or 255-6211-ND Panasonic LKQ1AF-5V-TV-8
        • manfriend
          • Jun 2018
          • 10
          My kid is bi-polar and she threw the board (Control 2) at me and the top popped off the relay and something(s) came out and I never found what it was.I'm new and couldn't find the actual replacement. Everything I found was out of stock. Thank you for the help!
          • hemant_2222
            Hemant
            • Jul 2015
            • 69
            • India
            #45
            Hi R_J,
            Here are further updates on this long Pending problem,
            Upon isolating few components i found
            When L405 was removed, the short remained between +3.3DSP and DGND
            When L409 was removed, the short to DGND at one pin of L409 is gone but other pin is shorted to DGND and when L408 was removed, L408's one is shorted to DGND.
            C488 and C489 were removed of the ckt and tested, they are good.
            So now, either one or more of the SMD capacitors are SHORTED or the DVDD, CVDD and VSS pins of the "No Replacement Part Available" DSP IC ( IC 44 ) is BAD.
            i am afraid if the DSP IC is bad then will i be able to get this changed or is it worth doing it ?
            Kindly input your views.
            Regards,
            Hemant.
            • hemant_2222
              Hemant
              • Jul 2015
              • 69
              • India
              #46
              Finally confirmed that the dsp ic was bad..with shorted dgnd and +3.3 dsp and in an attempt to remove itof the board with hit air gun..i think i have also fried the uP..now its all DEAD.
              Now i will have to keep this aside but whenever i'll come across this model i will try getting its digital board repalced in cheap offers..may be or use its resources as spares for another yamaha model..
              R_J, it was really nice working with you..i appreciate your help and expect the same goes on in furture.
              Thanks again to this forum..
              Soon will be back with another receiver.
              Bye for now.
              Hemant
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                by sam_sam_sam
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • Journey11
                Samsung TV won't turn on ... keeps cycling the power relay on & off
                by Journey11
                Hi All,
                First time posting here ... my name is Kevin but my friends call me Journey.
                I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                07-04-2024, 02:44 PM
                09-06-2024, 05:59 AM
              • supermattch
                HP 15dy-2021nr wont power on mystery volts
                by supermattch
                Hi everyone.
                I am diagnosing my personal laptop, because it wont power on and no leds light up.
                At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                09-23-2025, 12:13 PM
