FBT Mitus Active Stage Monitor 210 MA
  • Ike Mhlanga
    Ike
    • Feb 2018
    • Zimbabwe
    I am trying to resuscitate a dead Mitus 210MA.
    Everything seems ok on inspection. No Physical damage except FB5 on the input board which I suspect to be a Fast Blow Fuse of the surface mount type. Apart from that The unit is dead.
    There is power up to the rectifier of the SMPS and I get about 300V Dc.
    I need a schematic for the unit. FBT Mitus are Italian.
    Ive tried to communicate with them but it seems English is the barrier here.
    Any help will be apreciated.
    Regards
    Ike
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: FBT Mitus Active Stage Monitor 210 MA
    "FB" would indicate, to me, rather a ferrite bead.
    Can you trace, at least vaguely, where that trace goes, and/or where that comes from?
    Photos of the board(s) would help, too.
    <edit>
    Just for kicks, i looked up FBT over on http://www.elektrotanya.com . Got lots of results (arranged alphabetically), scrolled down to F, found a bunch of FBT things. The only FBT Mitus was "Promaxx".
    Downloaded the PDF, and whaddya know - it's all the same (with one or two component options) for loads of models - Mitus 206LA, 112A, 115A, 212 FSA, 118 SA, 121 SA, 210MA and a few Promaxx models as well.
    Suspicion confirmed, FB5 is indeed a ferrite bead, from the pin 1 of the two input XLRs to circuit ground (via the ground lift switch).
    Power supply's on page 6. I'd start with checking if there's any voltage across DZ1 (schematic says it should be 18v).
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Ike Mhlanga
      Ike
      • Feb 2018
      • Zimbabwe
      Hi Khron,
      Thanx a lot for the feedback. Its very much appreciated.
      I will download the schematics and give feedback.
      Regards
      Ike
        by momaka
        03-15-2023, 10:17 PM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
        Wise Wing F199 19'' LCD monitor - recapped
        by momaka
        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
        When I saw the Craigslist post, I wasn't...
        08-24-2020, 10:58 AM
