Marshall Stanmore Repair
  • Walzzu
    • May 2022
    • Finland
    #121
    Re: Marshall Stanmore Repair
    Could someone tell me the cold side voltages coming out of the transformer?
    Hot side is completely buggered, so I think i will bypass it and use different switching psu.
    My tristar transformer is showing opens.
    • DeeJayAlex
      • Aug 2016
      • 6
      #122
      This speaker barrel has 3 outputs
      # 2x14v and 1x30v
      • Walzzu
        • May 2022
        • Finland
        #123
        # 2x14v and 1x30v
        Hmm... Which voltage should go where?
        Two first are the grounds but what are the other 3?
        Thanks in advance.
        • DeeJayAlex
          • Aug 2016
          • 6
          #124
          #3-30v DC
          #1 and 2-14v DC
          • ceedjay
            • Dec 2018
            • sweden
            #125
            Hi.
            I have successfully repaired two stanmore. Both had identical faults. 220 ohm resistor to optocoupler burned. I have replaced all capacitors on the hot side. I have changed Mosfet,pwm ic, various resistors including 0,1 ohm shunt. I have replaced everything between pwm ic transformer output and the pwm ic. All diodes except the full bridge. All rectifier diodes after the 3 transformer output. 7812 and power amplifier. Both are now working but one of them have a high pitch transformer whine that also leaks into the sound. If I mute the sound the whining can be heared very clear out of the speaker.
            Does anyone have any idea what i could do?
            I have changed all 1000uf,470uf and 220uf capacitors as well.
            Regards
            • ceedjay
              • Dec 2018
              • sweden
              #126
              • ceedjay
                • Dec 2018
                • sweden
                #127
                Hi.
                I have tried to move the transformer between the two and the whining is not moving. This means that it is not the transformer that is "faulty". If i remove the rectifier diode on the 14V line that feeds the LM817 the whining disappears. Everything is working so what can be wrong, maybe something on the 5V?
                Regards
                • TimelessTech
                  • Apr 2023
                  • Netherlands
                  #128
                  I'm not sure if this thread is still active, but my Tristar 13030122 is as shorted as can be and I hoped that maybe someone on here knows a suitable replacement part for it. Maybe via Aliexpress or something. Kind regards
                  • hann
                    • Jul 2019
                    • 16
                    • Philippines
                    #129
                    how did you know that its shorted?
                    • Arl96
                      • May 2023
                      • Argentina
                      #130
                      Hi, I'm from Argentina. Does anyone know what are the models of the transistors marked in the photo? I have received a Marshall Stanmore team with the lack of these two
                      • SkyHeart
                        • Jul 2022
                        • 11
                        • Sweden
                        #131
                        D8: Fmg23s
                        u5: Lm317t
                        • NokLa
                          • Jul 2023
                          • Россия
                          #132
                          Hello, who can help with this chip?
                            • 22097
                            Parts with an equals sign = are usually made by Richtek https://www.badcaps.net/forum/showpo...84&postcount=2
                            It could be a Richtek RT9114B .Check the pinout carefully.
                            Datasheet: https://cdn.badcaps-static.com/pdfs/...0b114cc4ee.pdf
                            • Wetterstrand
                              • Jul 2023
                              • Sverige
                              #134
                              Hi friends!
                              I have an issue with a fried R7 on my board. Tried to replace it but the new one starts to melt almost immediately.
                              Any ideas on what the main cause could be? R6 is still ok and brings the correct resistance.
                              I'm currently novice, but soon pro Thankful for all the help I can get
                              • Hombre
                                • Jul 2013
                                • 231
                                • Croatia
                                #135
                                Your audio ic looks quite burned, on it's pins, i assume at least some of the ceramic caps around ic are measuring low resistance across the. If yes lift IC and check again for resistance on surrounding ceramic caps, if it went up your IC is toasted, and that could be a reason why R7 is burning
                                • janne911
                                  • Oct 2023
                                  • Finland
                                  #136
                                  Marshall Stanmore repair
                                  I have had a defect Marshall Stanmore (first edition) for a couple of years now that I meant to repair. However I haven't been able to find anyone with the similar issue until recently on youtube. However no suggestions to where I should begin troubleshooting.
                                  Have anybody had the similar issue and possibly a fix for it?
                                  Suggestions to where I should start also appreciated.
                                  Video of issue : https://youtu.be/vft56VFffi0?si=lgFmQAfKRaJ3-lnF
                                  Best regards,
                                  Janne
                                  • temaplav
                                    • Sep 2023
                                    • Ukraine
                                    #137
                                    Hello, at the beginning, the 220 Ohm resistor (standard situation) and the 12V stabilizer were burnt. After replacement, it turned out that the sound amplifier also burned out. After replacing it, everything worked,
                                    BUT THERE IS A DEFECT:
                                    1. When turning the volume knob to the minimum, the power supply is rebooted (I send the signal via bluetooth). Through aux, the same situation.
                                    2.
                                    The same situation occurs when I press pause on the phone from which I send the signal.
                                    The main voltage of 30V drops to 8-9V, due to PWM
                                    After the automatic reboot of the power supply unit, everything continues to work.​
                                    • Hkekkonen
                                      • Jan 2024
                                      • 8
                                      • Finland
                                      #138
                                      Hello everybody!
                                      My Stanmore is EU model.
                                      I had it on standard mode, not standby(power saving). And i forgot to turn it off. Not sure for how long, maybe week or two. Once i realised, light was gone and it would not power on. Who uses power saving mode anyways if there is an option? Now it decided to force it self into it!
                                      Fuse was ok. Visually nothing seemed to be burnt/defect, until i inspected it with microscope. C233 (220µF 25V capacitor) had two holes at the bottom part and some tiny debris close by. Replaced it with 330µF 35V, because it was closest i had.
                                      Well that didn't solve it, still nothing. I used thermal camera and only place with higher temp, than surroundings was near optocoupler 35°C. By reading this thread, i decided to replace the C4 (220µF 25V capacitor).
                                      It works again! 🎉
                                      Thank you all for sharing your knowlidge and the different issues with Stanmore speakers.
                                      P.s i have it on standby mode now.
                                      • temaplav
                                        • Sep 2023
                                        • Ukraine
                                        #139
                                        Please tell me the nominal value of the ZD5 zener diode
                                        • Hkekkonen
                                          • Jan 2024
                                          • 8
                                          • Finland
                                          #140
                                          Originally posted by Hkekkonen
                                          Hello everybody!
                                          Sorry its C4 (3.3uF 50V capacitor)
                                          • Kezi Gamer
                                            Marshall stanmore multi room
                                            by Kezi Gamer
                                            Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                                            03-24-2025, 08:37 AM
                                          • jingleslacks
                                            Marshall Stanmore II - chip flash
                                            by jingleslacks
                                            Hey Friends!
                                            I have both a live and demo unit. Demo unit firmware disables Bluetooth, power toggle, and other settings. Resets via button combos will not work on these. Reaching out to Marshall is not an option either.
                                            I copied my live CMOS chip and flashed it to the demo unit, but that didn't fix it (MX25U3235F) This has worked for other devices in the past. I'm not a chip expert, but I'm assuming the firmware is stored in another chip.
                                            If anyone has any experience or ideas, let's hear them!
                                            Stanmore II
                                            Stanmore 2​...
                                            03-23-2024, 05:09 PM
                                          • thuygsm
                                            Marshall Stanmore 2 (flash chip)
                                            by thuygsm
                                            hello
                                            in my case, the Bluetooth - AUX - RCA signal light goes off after 5 seconds and repeats, (sound is there then 5 seconds then gone and repeats)
                                            i forgot them and reconnected, but they do not play on the speaker, although i can still adjust the 3 modes Bluetooth - AUX - RCA (on the phone)
                                            after i loaded a new rom, i lost bluetooth connection and could not power off, no boot sound. i loaded the previously saved rom again, but the situation still cannot find bluetooth and boot sound
                                            hope everyone can help​
                                            04-08-2025, 10:27 PM
                                          • learnmore
                                            Help choosing replacement transformer for Levoit 600S SMPS
                                            by learnmore
                                            Hello Community,
                                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                            Peace
                                            LM...
                                            11-04-2025, 09:35 AM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
