Weekend score: Altec Lansing VS4121 Speakers for $7.59!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Was browsing the local classifieds for cheap audio crap last week. Found this system up for sale for ridiculously cheap.
    After a few days of not enough time or bad weather i could finally get to pick it up on Saturday. The seller also gave me a bag of "old electronics a neighbor gave me and i do not need", which contained various crap like old TV speakers, what appears to be a monitor power supply, a couple Samsung USB cables with a weird connector at the other end, could be some service interfaces, and a cheapo universal laptop power brick that just had a plastic tab on its voltage selector switch broken, some super glue and it works fine. Quite the score.
    Fault on the Altec Lansing system was described as "one sat works intermittently, sub cuts out". The subwoofer had been removed from the box and wires cut but it was in very good shape. He told me that he wanted to build the sub in another speaker box but never got round to it. He did not provide me with a signal cable for this system.
    So, i hooked up the system with my own signal cable and plugged it in. Both satellites sounded fine! I then took the amp out and replaced the wires for the subwoofer. It appeared to work as well and sounded very clean, no scratching or grinding noises in free air.
    I put the sub back in the box and fitted all the missing screws. Then i set up the system in the bedroom, with the sats to the sides and the sub under the bed and it sounds great.
    Later i did find that it does indeed cut out. However, not just the sub does it, the whole thing goes quiet. Responsible for this are the bass knob and the power switch that are on the front of one of the satellite speakers, and it only does that if you mess with the knobs a lot - leave them alone and the whole thing plays along with no problems!
    I did not see any obvious ways to take that satellite apart, but apparently it is possible: http://flybchen.blogspot.ro/2013/06/...ng-vs4121.html so i will look into it soon.
    All the caps inside this are Samxon and none are bloated. The PCB is very clean and sparse inside.
    There are another few mods that i would like to make to this system, first of all there is a minor amount of hum present at all times, i have read that this is a flaw present in all of them not just mine. Likely a small ground routing issue.
    Also, if the bass knob is turned towards minimum, it starts buzzing a little bit (not 50Hz hum, higher harmonics only, which is interesting). Then there is the slightly louder hum that occurs when i plug my laptop in while it is being connected to this system, i will try replacing the extension cord with a grounded one as i am pretty sure the lack of earth is my issue here. But to stop worrying about hum entirely, i am thinking of removing the existing mains transformer and marrying the power brick mentioned above (after recapping, of course!) to this system.
    Another thing i am looking to do is extend the length of the bass port and thus lower the tuning frequency of the box. While testing i have noticed that the woofer seems to unload a little below 40Hz despite it still having useful output at this point. This will reduce midbass response as a trade-off for the low-end extension, however i also have a large peak between 80-100Hz (which is likely to be also caused by the room), so this trade-off would actually be desired in my case.
    Finally, there is an amount of hiss that makes itself present as i turn the volume knob past 1/3, i am looking to adjust the gain internally so i do not have any more available than is required for the devices i hook up to it. I have checked the tone control IC's datasheet (LM1036N and it has pretty good specs, so the problem is either simply too much gain, or i may need to upgrade the opamps in the crossover.
    The amplifier in this is a TDA7377, where the two satellites are using two channels in single ended mode, with the sub bridged over the other two. For a "car radio" chip this certainly sounds impressive - yet another proof that good speakers are the most important thing in a sound system, and the amplifier is a second priority. This system has two front-firing tweeters on each sat, with a down-firing midrange speaker at their base. They put out beautifully clear sound with crisp highs. Compare this with anything Logitech has put out, where none of their systems ever sporting tweeters.
    A working TV? How boring!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Weekend score: Altec Lansing VS4121 Speakers for $7.59!
    Great score , especially for that price!
    • Logistics
      • Apr 2007
      • 721
      I remember picking up a mid-size Altec 2.1 system for $15 because, as the note on it read, "shuts off intermittently". Okay, a cap problem, maybe? So I bought them, and first thing I noticed was the sub volume was at maximum. I matched it toe meager volume of the satellites, and it has never shut off. I think the previous guy was tripping the auto-shut-down clipping protection, which was built into the units' main OpAmp.
      • yuzupatogik
        Help with replacing Capacitors on Altec Lansing ATP 3
        by yuzupatogik
        I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
        I can't find datasheets for the Samxon in any of the following variants:
        10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
        02-14-2025, 04:11 PM
        Electronic Goldmine has a weekend sale Wireless Charging Awesome Earbuds with Microphone CTS-MB3
        https://theelectronicgoldmine.com/products/g26731
        There regular price is $49.99 they are worth that but I would not buy any unless they are at $10.00
        When they had them on sale the first time I just add to an order that I was getting I have had wired earbuds before and was not impressed with the way they fit in your ear but these fit in your ears very well and easily put into your ear
        I bought a pair of them when they had them on sale for $10.00...
        06-22-2024, 07:38 AM
      • VaNDAL_UK
        Altec PC410 Auto PID Tune
        by VaNDAL_UK
        Anyone know how to get the Altech PC410 to initiate a P.I.D Tune?
        I can see the option, turn it on and it just flashed "tune" but nothing happens. Even tried running a profile after selecting tune.
        I remember doing it years ago on another machine but for the life of me I can't work it out this time.
        TIA.
        11-13-2024, 02:58 PM
        ASUS VivoBook P541NA Notebook Max Specification for Upgrade or Repair
        This specification for the ASUS VivoBook P541NA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P541NA boardview and P541NA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS VivoBook...
        09-06-2024, 08:00 AM
        ASUS ASUSPRO PU551LD-CN042G Notebook PU Specification for Upgrade or Repair
        This specification for the ASUS ASUSPRO PU551LD-CN042G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PU551LD-CN042G boardview and PU551LD-CN042G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 06:20 AM
