Harman Kardon AVR 370
  • Jjosip
    • Mar 2017
    • 9
    • Croatia
    Hi!
    I have a problem with my HK again... :-(
    It turns OFF sometimes. No messages, just orange led. It turns OFF quietly like it just stopped to Play. It happens even if AMP board is disconnected so it seems like it has nothing to do with output transistors. It seems I can force it if a volume is louder and when parts are starting to Heat more. I can hear something like a quiet boiling sound coming from power supply board but I can not detect which part exactly. I have measured capacitors capacity around that area and they seem ok.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Harman Kardon AVR 370
    On the previous page, somebody repaired a 3700 and it seems like, the standby transformer went out. Maybe, yours is on it's way out.
    I'm repairing a 1700, with the same standby transformer issue(TF91, if I remember correctly).
    • mastermix
      • Oct 2019
      • Poland
      Hello, sorry if this is not a good place and by the way this post but please help - a tip. AVR370 Harman / Kardon receiver - the standby indicator flashes orange. The PSU board does not show any damage, e.g. in the sense of visible damage or burning of any element. On the board is the OB2358APL converter - on pins 5 and 6 there is a voltage of about 330V, on pins 1 and 2 there is a voltage that varies between 8 and 11 V. Most of the elements have been checked, while the electrolytic capacitors have been replaced with new ones. Trafo TF91 is not short circuited.
      • PowellSkier
        Harman/Kardon AVR 645 returning to stand-by after a few seconds.
        by PowellSkier
        A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
        06-17-2024, 11:43 AM
      • funky2x
        Harman kardon onyx studio 7 Smd code
        by funky2x
        Cant find what smd code Y0DVA.
        sitting in Harman kardon onyx studio 7. Appreciate any help.
        05-29-2025, 03:44 PM
      • PowellSkier
        Cement resistor swap in Harman Kardon AVR
        by PowellSkier
        Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
        06-04-2024, 06:41 PM
      • falafinasul
        Harman Kardon AVR 3700 Fonte queimada
        by falafinasul
        Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
        I made a new Diagnostic and verified that the input source is shorted.
        Someone help
        02-24-2023, 05:51 PM
      • BlackScreen_22
        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
        by BlackScreen_22
        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
        I had no problems connecting mosfets and capacitors,...
        08-27-2024, 12:46 PM
