Roland KC-300 Works for a bit then goes into severe distortion
  • Doc38343
    • Apr 2015
    • 402
    Roland KC-300 Works for a bit then goes into severe distortion.
    When I put on the bench with my tone generator it was clear at first but when i raised the levels past "5" on input gain and main output it started small distortion at first then when i did a full sweep thru the frequency range it suddenly went to severely distorted.
    didn't know if any of you guys had seen one do this, going to try and find the schematic to start testing.
  • redwire
    • Dec 2010
    • 3912
    Re: Roland KC-300 Works for a bit then goes into severe distortion
    I found this Roland KC-300 preamp schematic, haven't looked for the power amp schematic. This can help you see if the trouble is the power amp or pre-amp.
    Keyboard amps are different from guitar amps, they have wider freq. response and not designed to overdrive.
    I use a clean line-level audio source, like CD player and listen to each section. You can inject (CD player) into the power amp input for example.
    These things get beat up, so fractured solder joints, broken pots, trashed speaker, damaged op-amp etc. are the things I look for.
    • KeyResults
      Roland SPA-120 Amplifier Tech Notes / SM / Schematic Source?
      by KeyResults
      Repairing a Roland SPA-120 amplifier, a solid-state early-mid 80's part of the Roland Rack. The PCB is Labled AP-124B. Was thinking lytics would resolve the nasty output on scope but all tested 100% for values, ESR, and leakage (very surprised!). Symptom is nasty wave form on both channels in Stereo mode, but clean in single channel mono (BTL) mode. The Output transistors test ok at room temp, but still could be faulty once heated up. Anyway, a schematic and some test point voltages would sure save some time. Thx!
      11-09-2024, 03:21 PM
    • oboyled
      AIWA mx-70 distortion
      by oboyled
      Re-curbing the amp , all caps seem visually ok, amp hits distortion at vol level 3, any input. Using aiwa 6 ohm speakers . Any ideas...
      09-04-2025, 11:56 AM
    • MakNCheese
      ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
      by MakNCheese
      I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
      Symptoms:
      • Severe lag across the system, including BIOS navigation.
      • Slow boot times and unresponsive performance in Windows.
      • Battery charges very slowly (e.g., ~5% in 2–3 hours).
      • No error messages or BSODs, just extreme sluggishness.
      What I've Tried:
      • Replaced
      06-04-2025, 12:48 AM
    • maleksa
      Roland JV-90 keyboard
      by maleksa
      I have a Roland JV-90 keyboard.
      When I switch it on from cold it works perfectly. However, after a few minutes it starts to act strangely. The LCD screen shows garbage, the LED lights starts to blink randomly and the sound that comes out are intermittent.
      I notice that the main IC (Roland R15239229) gets hot (more than 50 degrees C).
      What could be the problem?
      Why does it go crazy only after the circuit warms up? Could it be due to a blown capacitor, resistor or IC?
      Any help/pointers would be of great help.
      06-26-2023, 11:29 PM
    • ktmmotocross
      Asus X58c some distortion on output of ALC660 ic
      by ktmmotocross
      Hello.
      Have this old Asus X58c that have some distortion on output of ALC660 sound ic. distortion is in SPK and Headphone.
      i dont have spare ic, but it looks like a bad ic. have anybody some experience with this error?
      05-19-2023, 08:58 AM
