Repairing a Roland SPA-120 amplifier, a solid-state early-mid 80's part of the Roland Rack. The PCB is Labled AP-124B. Was thinking lytics would resolve the nasty output on scope but all tested 100% for values, ESR, and leakage (very surprised!). Symptom is nasty wave form on both channels in Stereo mode, but clean in single channel mono (BTL) mode. The Output transistors test ok at room temp, but still could be faulty once heated up. Anyway, a schematic and some test point voltages would sure save some time. Thx!
Roland SPA-120 Amplifier Tech Notes / SM / Schematic Source?
4 PhotosSo many interests and so little time!Tags: None -
CAPS: I focused on the same "ugly" Lytics. As stated, I pulled and tested w Kelvin Clips on Calibrated DE-5000 LCR Meter and Sencore LC53 (Value and Leakage). They may look ugly, but they're NOT the problem here. Haven't probed powered on yet. Only passive testing on obvious components, and found no abonormalities. Decided I'd like to find a schematic or Tech Notes for this SPA 120 unit if I can. So far, no dice. Not even for sale.
WAVEFORM / SCOPE: I usually snap pics of scope but I guess I forgot before teardown. When I power it up again I'll try to remember to get a pic. I can describe the clean sine wave on mono/BTL becomes Trapezoidal in Stereo mode. I also noted a high pitch "squeal" that sounded ominous. Evena simple block diagram would help me at this point. There are three preamp ICs which makes me wonder if two are on the stereo mode circuit, and the third is on the mono side.So many interests and so little time!Comment
This might be pretty similar just with added protect circuit...
Attached FilesComment
Thx. I appreciate that. I found that SPA-240 Tech Notes too with the same thought. The 240 is a much beefier design and apparently a much more popular unit as it seems to be well documented unlike the SPA-100.. There are multiple board revisions on the 240 too, but none match up with the SPA-120. Still, one of the revs may give me some strong hints that prove useful. Thanks again.So many interests and so little time!Comment
WAVEFORM / SCOPE: I usually snap pics of scope but I guess I forgot before teardown. When I power it up again I'll try to remember to get a pic. I can describe the clean sine wave on mono/BTL becomes Trapezoidal in Stereo mode. I also noted a high pitch "squeal" that sounded ominous. Evena simple block diagram would help me at this point. There are three preamp ICs which makes me wonder if two are on the stereo mode circuit, and the third is on the mono side.Comment
Maybe look and see if this PA is made under a different brand(s)? Sometimes you find at least one to 3 sub brands with the identical PA. I guess it's not a capacitor problem if you got that kind of equipment available to your disposal. I wont argue there. Do the transistors get hot while idling?
In any case, thanks to all. I will post the resolution as a follow-up along with the symptoms if anyone is interested.
KSo many interests and so little time!Comment
I've had to dive into several other projects since cracking this one open. I cannot recall if I removed the 8ohm load or not in Stereo mode. At this point I won't be able to work on this guy again until after the holidays. But, I'll get it singing again and follow-up. Hopefully not a nut loose at the controls!
This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-06-2024, 11:39 AM
This specification for the HP ProBook 450 G6 + Spectre Tech Tote Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Spectre Tech Tote boardview and 450 G6 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 10:51 AM
- Loading...
