Adcom GFA-555 ii power amp filter caps
  • Electone
    • Mar 2016
    • 19
    I picked up a mint 555ii last week and I'm just going over it. I did some measurements on the four big filter caps and it seems one of them may be dying. They are the original Adcom 15,000uF 100V caps.
    1. 15.96mF, ESR 1.2ohm, Vloss 0.9%
    2. 10.16mF, ESR 1.2ohm, Vloss 1.6%
    3. 15.92mF, ESR 1.3ohm, Vloss 1.9%
    4. 15.36mF, ESR 1.2ohm, Vloss 2.3%
    Questions are would it be ok to leave things as they are, or should I replace cap #2 or replace all four.
    The amps sounds perfectly fine as is and is very powerful.
    Thank-you in advance.
  • redwire
    • Dec 2010
    • 3912
    Re: Adcom GFA-555 ii power amp filter caps
    Nice!
    I would run the amp for a while, the caps might just need reforming, if it was out of service for a time. Then recheck the capacitance... But not in-circuit.
    They are expensive caps to change out.
    • Electone
      • Mar 2016
      • 19
      Sounds like a plan. Exact replacements would be cost prohibitive. I was looking at some CDE 382LXs but they are not screw terminals, so i'd have to modify the connections.
        You may not even notice anything unless you run the amp at full output power spec..
        • redwire
          • Dec 2010
          • 3912
          The CDE screw type cans are over $100 each, ouch. But only 75V or 100V. Snap-ins are $17 each. Not sure why.
            by momaka
            03-15-2023, 10:17 PM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
            by momaka
            03-12-2025, 03:42 PM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
