GLI Pro X Jam 15 iPod low output volume
  • jwillifixit
    • Apr 2017
    • 113
    • usa
    I've searched the site and have zero hits for this thing... in looking at the broader web it doesn't seem that these active powered "professional" speakers were very popular. I've come into possession of one and it's pretty beat up but "working" This model has inputs for:
    Mic/Line/Guitar and there's a built in file player that takes input from SD or USB and a 7 band eq.
    I'm in touch with a sales rep and am going to try to get some drawings but was just wondering if anyone here had any experience with amp issues like this on a guitar amp maybe? Perhaps someone could point me in the right place to start my diagnostics?
    Thanks so much
  • jazzie366
    • May 2016
    • 304
    Re: GLI Pro X Jam 15 iPod low output volume
    Thanks so much
    Does it put out low volume when using the iPod only?
    I've worked on AV systems used outdoors in camps before, this thing certainly looks like it's seen water before. I'd recommend un plugging the unit and letting it sit for a bit and then opening the amplifier panel.
    Take off all the screws on the edge of the metal amplifier panel. Once you do that, it should come off easily. Look for anything that looks abnormal, such as corrosion or rust. Give us some pictures of what you find as well so we can have a closer look.
    Popcorn.
    • jwillifixit
      • Apr 2017
      • 113
      • usa
      Awesome... glad to have someone join the investigation jazzie! The volume is low with both USB & SD card inputs. I'll have to dig for another input source to test (maybe I can find a mic). I'll crack it open this evening and see what I can discover and make another post.
      • jwillifixit
        • Apr 2017
        • 113
        • usa
        I couldn't find a source with an xlr or a 1/4" on it so just moved into the dissassembly & inspection... Other than it looks like someone puked all over the boards I don't see any popped cap's or fried components. There's a haze all over most of the boards. It looks like it has originated from the solder? Here's the pic's... I took the heat sink off the amp board to get a good look at the back. I didn't pull the other boards as the inputs are working, the eq is working, the mp3 decoder and usb/sd input are working.
        • jwillifixit
          • Apr 2017
          • 113
          • usa
          It's working... sound isn't "bad" for what it is and the condition I guess. I swear this is the biggest mp3 player I've ever seen (weighs like 50#'s). So I saw something that didn't look right. I mean it looked deliberate but wrong. Anyway I desoldered the bridge seen in the closeup and put it all back together and everything seems to be working as expected.
          To be honest I'm not now fully sure there was anything actually wrong with it when I "tested" it out the first time - you see I was using the main volume knob to turn it up and at max it wasn't very loud... didn't actually notice the Vol + and Vol - buttons on the mp3 player control. So after cleaning up that bridge and checking it out I tapped the Vol + button up to 25 and then turned the main vol knob up and this thing was pretty loud.
          Thanks for your guidance jazzie366!
          Thoughts about the bridge (not my diagnostic abilities)...
          • karthur
            Vizio D65x-G4 Volume changes on its own
            by karthur
            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
            06-05-2025, 08:13 AM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            by sam_sam_sam
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
            Corsair CX750M [Model 75-002019] - burned output toroid inductor
            by momaka
            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
            09-19-2021, 08:44 PM
          • CoppellTVRepair
            Troubleshooting PFC with SPC1012T not raising output
            by CoppellTVRepair
            It has been a long while since I posted here to ask anything....hope you can help.
            I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
            I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
            03-09-2025, 10:38 PM
