Power Amplifier Safety Modifications
  • diydidi
    • Sep 2012
    • 17
    • South Africa
    I have a Large power amplifier that needs repairing for a client of mine.
    It's a no-name brand stereo power amplifier and uses TO-3 lateral mosfets.
    It has a large 500VA toroidal power transformer as well as a smaller 60VA toroidal transformer for the relay speaker protect circuits.
    The builder didn't add any fusing except for a large 20A trip-switch wich doubles as the power-on switch too. I'm afraid the switch is too big in my opinion and will not trip during a fault situation. Removing it is not an option. Too much metal work.
    Amp at least has a soft start circuit built in for the large transformer.
    I would like to make it safer by adding a fuse on the mains side where the power enters.
    My question is, do each of the transformers need its own primary fuse, or will one suffice.
    Also how does one go about sizing the fuse/s? I assume they will all be slow blow.
    Mains where I am is 230V.
  • redwire
    • Dec 2010
    • 3912
    Re: Power Amplifier Safety Modifications
    You already posted this on EEVBLOG, how many answers do you need?
    • madan1
      • Nov 2016
      • 691
      Brief google search got me this - max Amps = KVa / Volts x 1000
      you have 0.5/230x1000=2.17A
      If you use a fuse for each transformer, probably a 2A one will be a good choice here.
      I do not guarantee that this formula is the correct one.. just found it on the internet .
        TOROIDAL transformer by itself has very large inrush current so by the time its outputs are connected to rectifiers and filter cap, the inrush curent will have to be figure out to be able to use proper type and size of the fuse.
        Just do the search on TOROIDAL transformer and inrush current associate with it.
        It should have softstart circuit.
        • diydidi
          • Sep 2012
          • 17
          • South Africa
          As many as I can get until I find the right answer.
          I don't want the guy's house burning down.
          End of my bussiness and hefty fine etc...
          Thanks for your reply.
          • MrCommunistGen
            Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
            by MrCommunistGen
            My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
            I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
            07-12-2021, 05:11 PM
          • jinu_j
            How to test Subwoofer Amplifier with only a multimeter
            by jinu_j
            Hi Folks
            Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
            Problem
            I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
            Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
            Any advice would be appreciated...
            08-29-2024, 02:05 AM
          • UserXP
            Mackie CR4 amplifier no sound
            by UserXP
            Hi, people.
            I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
            Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
            10-17-2020, 05:06 PM
          • mikey5791
            Help on car amplifier only one channel works
            by mikey5791
            Hi all forum members,
            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
            08-06-2025, 10:36 PM
          • Francesc V.
            Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
            by Francesc V.
            Hi:
            I've realized that one of the channels of this amplifier has no proper sound.
            This is the signal at the speakers output.
            As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
            Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
            07-15-2025, 01:33 AM
