Onkyo TX SV727: Found bad transistors, what else?
  • Zeppelin1007
    • Feb 2017
    • 27
    Re: Onkyo TX SV727: Found bad transistors, what else?
    Jiroy, this is what the guy i know uses
    http://www.apple.com/shop/product/HJ...duct-HJ102VC/A
    China is good for some things, but electrical components...ehhh little iffy on. There is a massive industrial surplus here in Ohio that's never let me down when i need ancient parts that arent made anymore. I'll give them a shot too.
    Update: got the 1k's soldered in. Did a quick continuity check, and was getting a short between B and E on the D2387. I figured it must be another shorted component in the circuit...i also touched up my solder job as it was a bit weak, and now I'm not getting the short. Now I'm scratching my head as to what caused it. Little leory to try powering it on unless i can be certain what my issue is. I just don't want to blow up more parts.
    Petahall, i take it these are equivilants. Would it be wise to do both channels to the new ones you listed here?
    Thanks guys.
    • madan1
      • Nov 2016
      • 670
      Do the bad channel, listen to it, if you notice differences consider changing the tr on the other channel.
      If you power the amp now ( with removed power tr ) you risk blowing another fuse due to other bad components which you have not found yet. I'd say better find them now than when you have the fresh set of transistors installed .
      As I said before - the amp should powerup properly if you have removed the bad components. If it dosa not want to start, then you have more work to do.
      • Zeppelin1007
        • Feb 2017
        • 27
        Success! She fired right up!
        OK! Now the fun part: Transistors and resistors.
        Thanks a ton guys!
        • petehall347
          • Jan 2015
          • 4425
          were the old outputs shorted ? they are darlingtons so wont test like a regular transistor. wont test shorted though if good .
          • Zeppelin1007
            • Feb 2017
            • 27
            The old 2SB1558 and 2SD2387? yes. Both showed shorts from B to E in both directions both in and out of circuit.
            • petehall347
              • Jan 2015
              • 4425
              #26
              farnell suggested the subs . check data sheets to be sure of a close match .
              • Zeppelin1007
                • Feb 2017
                • 27
                That's actually what I'm looking at petehall. Was trying to pinpoint what makes a transistor substitute compatible. Id obviously assume voltage and current ratings equal to and greater than the existing ones.
                Question: I saw a guy on youtube replace some transistors with NTE based ones, that came with a glass/plastic plate. Whats the purpose of this? the ones i pulled off had little sticky pads on the back for the heatsink. How is this different than me putting some thermal paste behind the transistors before i bolt em on?
                I was surprised she fired up! love the resistor test trick
                • petehall347
                  • Jan 2015
                  • 4425
                  #28
                  did you check dc offset ? i guess it wouldn't have powered up working anyway if not but maybe worth looking at in case .
                  • petehall347
                    • Jan 2015
                    • 4425
                    #29
                    the plastic looking plates are actually insulating mica . this needs thermal paste on each side .only a very thin layer . its there to fill scratches in the surfaces .
                    do not use thermal paste intended for computers as some of it is conductive .
                    the output transistors must be electrically insulated from the heat sink .always test with your meter after fitting them for short from cases to heat sink .
                    i always check with my meter for any possible shorts after soldering anything back in the boards . it doesn't take as long as fixing a burned out wreck .
                    • Zeppelin1007
                      • Feb 2017
                      • 27
                      Petehall, gotcha. Makes sense. Any kind of thermal paste you'd recommend? And what if the mica doesn't come with the transistors? Is there a generic supply somewhere i can grab more?
                      DC offset where?
                      • petehall347
                        • Jan 2015
                        • 4425
                        #31
                        dc offset is where speaker output comes from . if speaker relay clicks on then at speaker terminals . if not right where the emitter resistors join together at the output transistors . they are the biggest resistors and low ohms .
                        mica is bought separately .just have search around to find a supplier .
                        any quality non conductive thermal paste will be fine . i seem to remember dow corning or something like that in your part of the world is good .
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          #32
                          You can find the insulators at Mouser as well as the thermal grease.
                          http://www.mouser.com/Thermal-Manage...ulator&FS=True .
                          http://www.mouser.com/Tools-Supplies...grease&FS=True .
                          sigpicThe Sky Is Falling
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            #33
                            Definitely true . The best way to test a Darlington is to change it with a known good one . Its inside diode is really tricky .
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #34
                              The voltage difference between the Base pads should be measured to see if the idle current setting circuit is working properly.
                              • Zeppelin1007
                                • Feb 2017
                                • 27
                                Ok guys. I found the transistors, mica sheets the right size..turns out i have some non conductive thermal paste.
                                Struggling to find the dual 0.22ohm 5w ceramic resistors, or, find them at a reputable dealer. Does Farnell have them as well?
                                Ive read i can just put 2 resistors in manually. Any specific kind that must be had?
                                • jiroy
                                  • Jun 2016
                                  • 2416
                                  • Lebanon
                                  #36
                                  This page on Ebay include the Dual 0.22 Ohms , 5 W , Ceramic power resistors
                                  http://www.ebay.com/sch/i.html?_nkw=0.22+ohm
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I have purchased mine, from Ebay as well.
                                    • Zeppelin1007
                                      • Feb 2017
                                      • 27
                                      Ok guys. Sorry ive been slow to respond. Works getting out of hand and I'll be out of town for the weekend.
                                      So that means i ordered the transistors and mica so they'll arrive by the time i get back
                                      Ok ok on eBay. Makes sense. Just didnt know if there was some secret stash online i didnt know about lol.
                                      Anybody see a problem with me buying single resistors and pairing them up? I see plenty of 5W singles on ebay. Don't feel like waiting the month for the slow boat from china (nor do i trust it lol)
                                      Thanks guys!
                                      • madan1
                                        • Nov 2016
                                        • 670
                                        #39
                                        Yes, you can use 2 single resistors instead 1 double.
                                        • Zeppelin1007
                                          • Feb 2017
                                          • 27
                                          Welp. I replaced the transistors, made a dual resistor, soldered it all in and she fired up!
                                          There is a second relay on a delay that turns on after the thing powers up that clicks on.
                                          Now, before I button it all up, should I be checking voltages/bias? If so, I hope its at the terminals and not on the board.
                                          Thanks guys. This has been sitting on my "someday I'll learn how to fix this" pile. Easily 6 years.
                                          • Francesc V.
                                            Onkyo A8200 - Not the right voltages in some transistors
                                            by Francesc V.
                                            Hi:
                                            I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                                            With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                                            Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                                            Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                                            I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                                            04-19-2025, 07:17 AM
                                          • FrancescoV
                                            Onkyo HT-R390 no sound output, video output ok
                                            by FrancescoV
                                            Good morning everyone,
                                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                            The firmware reported is the following:
                                            M:1.00/11107BLP
                                            D:?.??/????????
                                            O:1.00/11107AL
                                            The DSP firmware given the question marks seems corrupt.
                                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                            05-11-2025, 02:59 AM
                                          • redbaron1007
                                            Sundown SFB-8000D What are these transistors?
                                            by redbaron1007
                                            I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
                                            My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
                                            11-12-2023, 07:30 PM
                                          • Bob Wong
                                            MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                                            by Bob Wong
                                            Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                                            In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                                            P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                                            03-15-2025, 02:02 PM
                                          • hyva_ana
                                            Marantz PM-66SE Burns Transistors
                                            by hyva_ana
                                            While ago I replaced those big filter caps to that amplifier. After that started to happen. I connected the amplifier normally to the mains and almost immediately several transistors burned out. I really didn't do anything else (at least on purpose) than replaced those big caps C801 and C802.
                                            After that I replaced those burned transistors (I can't remember exactly what they were) and measured all the others, and now everything should be ok. But, when I power up that amplifier part with two bench power supplies connected in series there is obviously still something...
                                            02-11-2023, 06:34 AM
