soundcraft spirit m4 mixer troubleshooting
  • 5inc
    • 120
    • Spain
    #61
    Re: soundcraft spirit m4 mixer troubleshooting
    No, the trace seems to end after r457 and r466, they are just after the pan pot on monochannel1, and should go to switch12 at masterA.
    It doesn't dissapear, but it is greatly reduced, from there I have to turn the gain right up untill it clips to hear a faint something.
    The opamps are ne5532, and checking the otrher opamps of masterA, it seems like the whole line is out, they all have the same 0.7v on one of the Vcc ends.... gonna check master B
    • petehall347
      • Jan 2015
      • 4426
      #62
      http://vakits.com/sites/default/file...uct/NE5532.JPG
      • petehall347
        • Jan 2015
        • 4426
        #63
        always check data sheets and the manual ..
        i know some op amps will work from single or dual voltages ..
        you need to trace where pin 4 goes . and use that ground point as your ground point . that is of course its being fed with a single positive supply only .
        • petehall347
          • Jan 2015
          • 4426
          #64
          i have just been all over the manual and they seem to have conveniently missed off the power supply .
          • Khron
            • Sep 2006
            • 1350
            • Finland
            #65
            Pin 4 will most definitely NOT go to a ground - all the opamps in this mixer are supplied with symmetrical voltages (roughly +/-13v as measured).
            petehall347, have you even looked at the schematics? They're linked in one of the posts on the first page. It's best not to assume too many things, when "blindly" (no offense) instructing less experienced people to connect and test things, imho...
            I don't know what ancient datasheet you dug out that picture from, but it's... inaccurate - https://cdn.badcaps-static.com/pdfs/...cb7311d307.pdf
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • petehall347
              • Jan 2015
              • 4426
              #66
              i got the manual from an earlier post . what page is the power supply on ?
              and yes ne5532 can be wired both ways as far as i am aware .
              i did say trace where pin 4 goes to too be sure .
              • petehall347
                • Jan 2015
                • 4426
                #67
                like this ...
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  #68
                  You might've found the manual, but you've obviously NOT read through the whole thread (or not carefully enough).
                  As you can quite clearly see in the schematics, all the op-amps are NOT powered from a single supply, but from a split-supply.
                  Look on page 2 of the service manual, on the bottom, mid-right side. What do you see?
                  Yes, opamps CAN be used with a single supply, but if that's (clearly) not the case here... What's the point?
                  Originally posted by 5inc
                  whoa, I think I should have re-read my post after replying, it is a bit unllegible, sorry about that.
                  I was reading volts, and i had the black lead on the chassis holding the boards.
                  And yes, CN6 has a 42V at pin 1, +13,7v at pins 3-4, and the negative at pins 9-10.
                  And CN9 has correct voltages at 3-4, 9-10.
                  https://www.badcaps.net/forum/showpo...30&postcount=5
                  "The negative", in this case, is the -13.7v at pins 9-10 of CN6.
                  • petehall347
                    • Jan 2015
                    • 4426
                    #69
                    ok i am on sheet 2 and cannot see a single ne5532 or any reference to the power supply for them . this manual is one of the worst i have ever seen .. its more like a bloody car wiring diagram with numbered wires .
                    and where is the actual regulated supply diagram ? this is where to start as i suggested at the start of this thread .
                    • 5inc
                      • 120
                      • Spain
                      #70
                      hmm... it doesn't go straight to gnd... it passes through a few caps... and it goes down to the fader chasisses.
                      By my ground point you mean where I put tracer and injecter gnds?
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        #71
                        *sigh*
                        I'll tell you a little hint - for at least the last 3-4 decades, (dual) opamp pinouts are pretty standard. Pin 8 = positive supply, pin 4 = negative supply, etc.
                        I'll tell you another hint - both the NE5532 and the TL072 (as seen on the indicated page 2) are dual opamps, with IDENTICAL PINOUTS.
                        As pointed out in the quote / link from the first page of this thread, the power supply itself WORKS as it should. Since it does, and the rest of the mixer / bad channel up until the suspicious opamp (as tested by the thread starter with the circuit tracer) also WORKS. So what's with this sudden fixation on the power supply?
                        PS: You can find details about how your precious NE5532's are powered on the bottom of page 10, if you couldn't be bothered to find'em...
                        • petehall347
                          • Jan 2015
                          • 4426
                          #72
                          well if the negative supply for those op amps is missing the supply is a very good start is it not ? then look for a current limiting resistor to check to make sure its not burned out .
                          if this schematic was in one piece i could have had things worked out much sooner .
                          p.s i have now found reference to the dual supply for the ne5532 on sheet 10 .
                          the ground reference is AGND for these voltages .
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            #73
                            Haste makes waste... And we don't always have the luxury of schematics or service manuals as perfect as we'd like them.
                            <bad joke / gross exaggeration> That's what separates the men from the boys... <end of joke>
                            But as pointed out, the power supply itself is fine, since it measures fine on most / all(?) other opamps on the board.
                            As i've posted just earlier today, i've dealt with another Soundcraft mixer a few years ago, that had suffered a spillage, and a couple of power traces were corroded away by that.
                            Good call on the series resistor suspicion, though. R666 on -V_MASTA_L would be the one in question.
                            • 5inc
                              • 120
                              • Spain
                              #74
                              ok, guys, I got lost in your men-talk.
                              I havn't seen any corrosion anywhere on the board, appart from a few cut traces.
                              But you hit bingo on that "-V_MASTA_L" Khron, I have been looking for that basterd for the last hour (where is it??), and r666 is missing, devil resistor.
                              • 5inc
                                • 120
                                • Spain
                                #75
                                oops, it was you pete, bingo
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  #76
                                  What traces are cut? Were they part of that huge "grounding mod" that was done before you opened it up?
                                  I can't take all the credit, petehall347 came up with the idea, i only "gave a name and a face" to the potential issue. Glad to hear you found the culprit, though
                                  Although... "missing", how? Burnt off? Or desoldered?
                                  • 5inc
                                    • 120
                                    • Spain
                                    #77
                                    it's gone, desoldered.
                                    I'm looking for the cut traces, if you mant me to say them all.
                                    • petehall347
                                      • Jan 2015
                                      • 4426
                                      #78
                                      where did you find r666 in the literature ? . what sheet number ? i cant see any power supply at all at this end .. there must be a similar one for the positive supply . sometimes it makes it easier to be looking for something else .i know it does each time i lose something . might be an age thing on my part though .
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        #79
                                        That's just really, really weird...
                                        If there's so many of them, don't bother
                                        Replace that 10 ohm R666 and see what happens then.
                                        Is it ironic that R666 was the problem?
                                        • Khron
                                          • Sep 2006
                                          • 1350
                                          • Finland
                                          #80
                                          Page 15, mid-right side.
                                          I got the hunch from "The opamps are ne5532, and checking the otrher opamps of masterA, it seems like the whole line is out, they all have the same 0.7v on one of the Vcc ends."
                                          The NE5532's of the "Master A" section are all supplied from +/-V_MASTA_L (page 10), which are "created" on page 15, through R667 and R666.
                                          • Longon
                                            Behringer Pro Mixer DJX-750
                                            by Longon
                                            Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                            Today, 02:17 PM
                                          • BigOof
                                            Marantz SR5007 popping on volume change and mute in Direct Mode
                                            by BigOof
                                            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                            12-12-2024, 06:15 AM
                                          • Bektronics
                                            Schematic Digital Audio mixer RCF type M18
                                            by Bektronics
                                            Hello dear audio friends.
                                            I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                            The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                            I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                            Thanks in advance if anyone can help me with this schematic.
                                            Of course, all information about this digital mixer and possibly references...
                                            07-24-2023, 06:40 AM
                                          • blues_spirit
                                            practical courses for troubleshooting pc motherboards
                                            by blues_spirit
                                            Hello from France,
                                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                            Do you think this is feasible for me? I...
                                            12-18-2022, 12:56 PM
                                          • Thermaltake
                                            Yahama mixer PSU difference
                                            by Thermaltake
                                            I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
                                            I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
                                            And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
                                            I google a little and found that there is this part number...
                                            09-17-2024, 11:52 AM
