YAMAHA RX-V375 repair tips.
  • capwizard
    • Jun 2016
    • 1991
    By BaHa :Hi guys! For the ones who has the RX-V375, after suffering for hours, following circuits, tracks, cables, checking voltages, signals... I finally found out how to "fix" (it wasn't damaged, just locked) mine!! Just press and hold buttons TONE, INFO and POWER for 3 seconds (if it turns on in less than 3 seconds, don't release the buttons yet, hold them for 3s!), after that, turn the unit off on the Power button and turn it on again, it should work fine now (if nothing else is damaged inside). Good luck!
    https://www.badcaps.net/forum/showth...t=32444&page=3
    YES! Good luck! I try that still not work, I found two power Tr shorted, 2 badcaps, one loose connector and 100 of screws then MISSION COMPLETE.
    YAMAHA RX-V375 SERVICE MANUAL
  • sanalelevenstar
    Yamaha RX-V485 Wn9711 Update
    by sanalelevenstar
    Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
    I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
    I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
    12-04-2024, 04:32 AM
  • jjne
    Yamaha RX V675 sound issues
    by jjne
    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
    At first I thought it was either a speaker relay or the DSP, but I don't think...
    06-24-2025, 07:01 AM
  • AlexVG
    YAMAHA CLP-550 without of sound
    by AlexVG
    Hi.
    I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
    I have replaced all green marked elements, but it gave me nothing.
    The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
    But it is custom YAMAHA's chip, and I can't find any information about it.
    Maybe somebody came across with the same issue?
    Any information will be very useful. I will be very appreciated.
    Thank you....
    06-08-2025, 09:29 AM
  • estabilito
    Tips geting oxidized when using wick
    by estabilito
    Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
    i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
    Temperature: 350-365celsius
    station: jbc cd-2bqe
    Wick: edsyn
    flux: warton hf rework jelly
    Do you have any tips?...
    04-12-2025, 11:55 AM
  • hemant_2222
    Yamaha RX-A1020 full dead
    by hemant_2222
    Hello Everyone,
    Greetings!
    It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
    09-14-2024, 11:25 AM
