Soundcraft 324 Live digital mixer repair, all LED flash, power supply fault
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    A neighbour brought me this mixer in with a sudden fault: it doesn't boot and instead it keeps flashing all LEDs in the front board.
    I started without any documentation at hand and I was quite lost. I deducted that ±15V from PSU were down for some reason. No shorts in consumer side. There were 5V and 48V (for mic phantom), but that's all.
    I was about to give up, but as an act of despair I contacted Soundcraft headquarters requesting some help or documentation. Against all odds, I got a prompt reply from Rick Morris attaching schematics of both the mixer and its PSU. Well, that's a boost!
    With the aid of PSU schematic I spotted the common link between +15V and -15V: /PWRGOOD signal (0V = "power good"). It was always 5V, preventing the system from booting and from enabling ±15V.
    With the PSU isolated, I shorted PWRGOOD to GND and then both +15V -15V show up! Why it isn't pulled to low level by the PSU itself? The PSU generates 5V and phantom 48V fine, so it had to be a very silly thing. Following the /PWRGOOD signal to the primary side, LM393N comparator outputs 0V (good), so the photocoupler CNY17-3 should had to pull /PWRGOOD to ground at secondary side, but it didn't. Compared both CNY17-3 and IC1 reads different than IC2 in the diode side. Also R79 has changed color from blue to dark green due to heating. I replaced IC1 photocoupler with a equivalent LTV702VB and the problem was gone! Now system boots OK.
    Thanks again to Rick Morris from Soundcraft. Without his help I wouldn't have succeeded.
  • midibob
    • Nov 2008
    • 285
    Re: Soundcraft 324 Live digital mixer repair, all LED flash, power supply fault
    It just goes to show, sometimes manufacturers can be very helpful. Thanks for posting.
    Midibob
    • Bektronics
      Schematic Digital Audio mixer RCF type M18
      by Bektronics
      Hello dear audio friends.
      I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
      The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
      I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
      Thanks in advance if anyone can help me with this schematic.
      Of course, all information about this digital mixer and possibly references...
      07-24-2023, 06:40 AM
    • Longon
      Behringer Pro Mixer DJX-750
      by Longon
      Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
      08-11-2025, 02:17 PM
    • Thermaltake
      Yahama mixer PSU difference
      by Thermaltake
      I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
      I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
      And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
      I google a little and found that there is this part number...
      09-17-2024, 11:52 AM
    • Thermaltake
      Power button on Behringer Xenyx 1204USB mixer dead ?
      by Thermaltake
      Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
      I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
      08-16-2022, 03:22 AM
    • wolf1976
      is there any univarsal wifi motherboard that supports and digital tvs ?
      by wolf1976
      hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
      is there ?
      do you have to suggest me one ?
      thanks on advance...
      01-05-2025, 04:29 PM
