Yamaha RX-V390RDS
  • mikkhh
    • Jun 2016
    • 13
    • Estonia
    Yamaha RX-V390RDS
    Okay so I got my hands on this nice Yamaha receiver. But it powers on then shuts off after a second. After fiddlind around with pressing all the button combinatons the receiver started workiong and worked excellently for a month, then the problem came back.The output relay doesn't click. But some standby voltages were wrong. I replaced all 2sc1740s and dta114 on the front board. The problem is still the same, but the dta114 voltage appears to be correct.
    It seems to me that, either the replacement transistors are faulty (hopefully I will receive my transistor tester in the next few days), some capacitors (will receive the esr tester in the next few days) are faulty on the output board (since the reciever is 20 years old). Since the old soviet y 101 receivers had similar problems, and the cure was new capacitors. The front panel ceramic caps are ok. The standby board is working fine (checked in another similar receiver - rx v385, but the other receiver cannot be used for anything else, since the standby board is the only fitting part, some voltages could be checked, since they are quite similar in layout).
    I will replace the 2sa933 transistor on the front panel, if I cannot find anything better to try. As a last resort I will just "disable" the protect circuitry and when the receiver dies then it will die in flames .
  • mikkhh
    • Jun 2016
    • 13
    • Estonia
    Re: Yamaha RX-V390RDS
    So the DTA114 was just part of the protection circuitry, it was not faulty. It seems like the problem is actually on the main pcb voltage regulation. Will check q133 and d109/110 on the main pcb.
    • mikkhh
      • Jun 2016
      • 13
      • Estonia
      so those components seem to be bit off at the readings, but only desoldering tells for sure.
      • redbaron1007
        Yamaha HTR-3065 No power/No Standby
        by redbaron1007
        I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
        S9 13.7V
        Pwr Ry 0V
        AC Det 9.1V
        Mgnd 0V GND
        The two pins on the transformer for the operation...
        09-12-2024, 03:04 PM
      • Pete D
        Yamaha HTR-5460 Receiver protection code info.
        by Pete D
        Hi Guys, My first time on the forum.
        I have a Yamaha HTR-5460 Receiver that I have used for a few years. It has recently developed a problem of giving a pop in the speakers and then shutting down. This is intermittent and might happen after an hour or a couple of days of playing.
        I have put it into Diagnostic Mode and it comes up with code “PS PRT 020 B”. According to the service manual “PS PRT” signifies a power supply problem in the mains transformer, 5V or 12V DC supplies. I'm assuming that the “020 B” part of the code would define which one of these...
        11-03-2023, 07:00 AM
      • sanalelevenstar
        Yamaha RX-V485 receiver. After encountering a "version error"
        by sanalelevenstar
        I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
        After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
        I managed to find the service...
        09-10-2025, 01:54 AM
      • hemant_2222
        Yamaha RX-V373 no voltage on the standby switch
        by hemant_2222
        Could someone please advise on this. I have this Yamaha taken from a friend for repair, especially since it had a USB for my interest. But it is not working at all.
        Here is what has been done so far. Checking the standby switch did not show 3.3 volts on one of its pins, the other was ground. it is showing as 0.60 volts. I have changed the switch as it had some resistance even when normally open. After changing the switch, I next saw that PIN 91 is not showing 3.3 volts.
        The processor clock pin show 2.8 on pin 18 (XOUT) and 0.80 on pin...
        11-29-2022, 11:33 PM
      • sanalelevenstar
        Yamaha RX-V485 Wn9711 Update
        by sanalelevenstar
        Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
        I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
        I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
        12-04-2024, 04:32 AM
