Sony CMT-BX5 (HCD-CBX5) repair, No disc, bad quality spindle motor JQ24-40H400
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    "No disc" message and typical pickup squeal of "want the disc to start spinning but it doesn't spin!!".
    I find the crappy JQ brand motor sadly common in many Sony equipment from mid 2000. They're present in both audio CD mechanisms (KSM213xxx) and DVD (KHM313AAA). They can be exercised with 6V and it usually relive, but with high chances of return. Not worth it.
    I've replaced it with a scrapped ol' good Mabuchi RF-310T-11400, adjusting disc support height to exactly 19.4mm (from support top surface to mechanism metal frame), using a caliper.
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
  • CyberPhoenix
    Issue with picture quality of Sony bravia TV
    by CyberPhoenix
    Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
    01-22-2024, 02:08 AM
  • Junior††
    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
    by Junior††
    Good Afternoon fellas,
    Issue:
    Disc is showing as not supported when a disc is put in.
    Here's what I've done, you can skip this if you just wanna know the question:
    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
    - reflowed the disc drive connector
    -reflowed the chip in question (shown on image)
    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
    Question:
    I...
    02-19-2025, 12:48 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • m4a2t0t
    Pioneer Laseractive CLD-A100
    by m4a2t0t
    The disc spindle motor will not spin on this unit. The motor has 2.5v on both sides and does not change.
    I have a second unit that works 100% that needed a recap. I tried the PSU before and after the recap. No change. I swapped the video board that has all of the ICs on it and it still wont spin. I injected 2.5v into CN2 (the motor connector) and the motor spun.
    The pickup assembly moves back and forth. The laser appears to light up, although it doesn't look like any newer laser diode with a well defined dot in the center. I can see red light refracting off the lens...
    09-11-2023, 09:01 PM
