Logitech X-230 amplifier - upgrade possibilities?
  • Leopard
    • Mar 2008
    • 109
    • Finland
    I recently opened up my Logitech X-230 subwoofer, and it has a built-in amplifier for the satellites and the sub itself, of course. I discovered some "Chang" branded capacitors on the amplifier PCB, and would like to know if they are reliable (probably not ) or if someone has run across blown Changs. I will probably change them sooner or later as soon as I find out for what purpose each cap is. Gotta check what kind of op-amp(s?) it uses so I can find a more high-quality replacement. Will return with pics later.
  • tonyynguyen
    • Aug 2008
    • 20
    • us
    Re: Logitech X-230 amplifier - upgrade possibilities?
    Looking forward to see how well your modification turns out. As I am also in the same boat as you. Trying to recap and upgrade the opamp on a Creative SBS-340.
    • Leopard
      • Mar 2008
      • 109
      • Finland
      Ok, here are the pics.
      As you can see, the large cap is a Chang 4700uF 25V one. The smallest caps without vents scattered around the PCB are ChengX branded and the two caps with + vents are Cheng branded. I guess these come from the same vendor, and this is just some sort of cap series naming technique.
      The large 14-pin IC is the op-amp with the series marking "TL074CN". At first I though that the 8-pin chip could be it, but decided to check around for it on the Internet and found out that it's just a MOSFET.
      Now onto the questions.
      - Is there any high-quality suitable replacement available for the TL074CN IC?
      - There's a cap by the op-amp, what purpose does it serve? Or what purpose does each cap serve, which ones should I replace with audio-grade or film caps and which ones are for power supply usage and to be replaced with quality brand caps?
      • Leopard
        • Mar 2008
        • 109
        • Finland
        Ok - the 8-pin chip is not a MOSFET. I was led to a wrong datasheet.
        It has the markings:
        4565D
        JRC
        Now I'm really confused - is this JRC chip like a headphone op-amp or an op-amp for the subwoofer? The 14-pin IC is a quad-channel op-amp, so would that be the one responsible for the stereo speakers, since they both have 2 drivers and 2x2 equals 4. I'm a noob at this section so don't be surprised by these questions.
        Anyway, has anyone ordered sample parts from National Semiconductor before? Do they charge money for the samples or just for the shipping?
        And the final question - I'm going to replace the large 4700uF Chang cap. Do amplifier circuits require low-ESR or will a generic cap from a quality brand do?
        • tonyynguyen
          • Aug 2008
          • 20
          • us
          I just ordered the LME49860NA sample opamp from National Semiconductor. If you have a business email address, they will provide free shipping. They gave me next day air with UPS.
          • Leopard
            • Mar 2008
            • 109
            • Finland
            Nice to hear! I do have an email address which I can use for free shipping. Report back if they charge money for the samples or if they are free
            • davmax
              • Dec 2005
              • 899
              4565D
              JRC
              I see the LME49860NA as a great replacement for the 4565D. This is the preamp stage where background noise is important, and distortion on this amp is low. However in terms of distortion the main distorting amp is the TDA7377 if driven above ten watts in bridge connection or 4 watts single ended. So like any amp if driven hard distortion will be evident.
              Re 4700uF. Standard electro will do. I suspect that additional non electro caps are used to deal with high frequency ripple at the power amps. It will not hurt to use a low ESR cap.
              Gigabyte EP45-DS3L Ultra Reliable (Power saver)
              Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
              160Gb WD SATAII Server grade
              Nvidia 8500GT 256Mb
              160Gb WD eSATAII Server grade for backup.
              Samsung 18x DVD writer
              Pioneer 16x DVD writer + 6x Dual layer
              33 way card reader
              Windows XP Pro SP3
              Thermaltake Matrix case with 430W Silent Power
              17" Benq FP737s LCD monitor
              HP Officejet Pro K5300 with refillable tanks
              • tonyynguyen
                • Aug 2008
                • 20
                • us
                I decided to recap my Creative SBS340 speakers and upgraded the opamp to the LME49860NA.
                • Leopard
                  • Mar 2008
                  • 109
                  • Finland
                  Good job! Did you notice any major improvement in sound? And did National charge for the samples (not shipping, the samples themselves)?
                  • tonyynguyen
                    • Aug 2008
                    • 20
                    • us
                    The audio is cleaner then before. There use to be clipping coming from the speakers at high volume before, and now its completely gone. I have the amp powering 2 Yamaha bookshelf speakers.
                    Nope, National didn't charge me anything for the samples. I believe as long you have a business email (something not @yahoo/gmail etc), then National would even ship it for free.
                    • Leopard
                      • Mar 2008
                      • 109
                      • Finland
                      Oh very yes!
                      I received my samples today (3x LME49860NA and 3x LME49740NA) and replaced the 4565D. Didn't replace the TL074CN yet, since it took forever to desolder even the 8-pin op-amp... So I'll replace the 14-pin TL074CN with the LME49740NA during the weekend when I have more spare time.
                      Results as of now:
                      - High volumes improved by a very noticeable amount. Audio is much cleaner just like tonyynguen said.
                      - Bass control improved a lot. The subwoofer gives off a more "thump" sound instead of "whomph".
                      - Overall midrange quality got much better, overdriven guitars much nicer and vocalists' sounds do not drown into the bass anymore.
                      - I also noticed superior audio transparency over the 4565D.
                      I'll have to wait more so the new op-amp burns in before giving final judgements. But for now, the improvement is surprisingly large!
                      I'll post back when I replace the TL074CN during weekend. Maybe I should replace the input filter caps aswell - there are two very small ventless caps by the input area.
                      P.S. The LME49740NA is a suitable replacement for the TL074CN, right?
                      • Leopard
                        • Mar 2008
                        • 109
                        • Finland
                        Ok - I replaced the TN074CL without success. While desoldering the IC, two of the fourteen contact pads came off. No surprise, the thing doesn't work properly anymore. At first it would not produce any sound - only some buzz. Now that I soldered jumper wires in, the satellites work but the subwoofer just gives off noise. I'll now try to clean the solder joint area with isopropyl alcohol and resolder bad-looking joints if I find any. I'll post back if I get positive results later today...
                        • Leopard
                          • Mar 2008
                          • 109
                          • Finland
                          SUCCESS!
                          There was a third contact pad which had gone bad. A third jumper wire and everything works a-ok now!
                          • zandrax
                            Hit and miss
                            • Dec 2007
                            • 1157
                            • Italy
                            Hooray
                            Zandrax
                            Have an happy life.
                            • feistydragon
                              • Jan 2009
                              • 4
                              SUCCESS!
                              ihello guys, i'm new to this forum. i decided also to makean upgrade to my x230 and started by changing the caps with better quality electrolytics and also mkt. i also changed the np's into the satelites and also the variable resistor for the woofer control instead of 10KΩ i puted 20KΩ. the sound was much clearer and also the woofer control is beter. reading your conversations i decided to change also the opamp and the quadamp. did you order it from the states or uk? coud you tell me where from please, because here in greece the cost is about 30euro for the 2 ic's
                              • Leopard
                                • Mar 2008
                                • 109
                                • Finland
                                I ordered samples from National Semiconductor. The samples are free and they provide free shipment if you have a "business" e-mail adress. (Not hotmail, gmail, yahoo etc.)
                                • feistydragon
                                  • Jan 2009
                                  • 4
                                  oh, ok many thanx
                                  • feistydragon
                                    • Jan 2009
                                    • 4
                                    excuse me but one last question. i understand the buisness email, but must i have an electronics shop, or they will send it to any buisness email?
                                    • tonyynguyen
                                      • Aug 2008
                                      • 20
                                      • us
                                      No its not required that you actually own a business. As long as the email domain isn't one of the free service type.
                                      • feistydragon
                                        • Jan 2009
                                        • 4
                                        hello guys, i ordered through a business email of a friend samles of lme49740na and lme49860na and they denied, saying that they cannot process my order and i should be adressed to national in germany! do you have any idea what to do?
                                          LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-12-2024, 01:58 PM
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
                                        • Widget
                                          Logitech R20 speakers - Replacing one of the speakers.
                                          by Widget
                                          Hi guys,
                                          I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                                          Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                                          Printed on the back of the Logitech speaker is;
                                          LOGITECH...
                                          05-29-2024, 07:07 AM
                                        • UserXP
                                          Mackie CR4 amplifier no sound
                                          by UserXP
                                          Hi, people.
                                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                          10-17-2020, 05:06 PM
