Logitech X-230 amplifier - upgrade possibilities?
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Re: Logitech X-230 amplifier - upgrade possibilities?
    Originally posted by feistydragon
    hello guys, i ordered through a business email of a friend samles of lme49740na and lme49860na and they denied, saying that they cannot process my order and i should be adressed to national in germany! do you have any idea what to do?
    Rather odd as you live in Greece that they told to do business with National in Germany... Could you paste the e-mail or the critical parts of it?
    And also, what do you mean with this:
    i also changed the np's into the satelites
    You changed some components, but what exactly? NP doesn't ring any bell for me. Thanks!
    • Logistics
      • Apr 2007
      • 721
      He changed the non-polarized caps in the satelites?
      • slavun
        • Feb 2009
        Hi to All,
        I have Philips SPA9300 2.1 system. I decided to change the Op amps inside. There were 2 JRC4558D. In my opinion these amps are for active filters. I changed them with OPA2132P. Maybe there is an improvement or I presume.
        The best way is to solder 8DIP sockets in order to try different amps .
        http://www.bgsportal.blogspot.com/
          LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
          This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
          09-12-2024, 01:58 PM
        • MrCommunistGen
          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
          by MrCommunistGen
          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
          07-12-2021, 05:11 PM
        • jinu_j
          How to test Subwoofer Amplifier with only a multimeter
          by jinu_j
          Hi Folks
          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
          Problem
          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
          Any advice would be appreciated...
          08-29-2024, 02:05 AM
        • Widget
          Logitech R20 speakers - Replacing one of the speakers.
          by Widget
          Hi guys,
          I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
          Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
          Printed on the back of the Logitech speaker is;
          LOGITECH...
          05-29-2024, 07:07 AM
        • UserXP
          Mackie CR4 amplifier no sound
          by UserXP
          Hi, people.
          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
          10-17-2020, 05:06 PM
