Sony amp "protect" issue
  • pentium
    • Mar 2006
    • 2778
    First of, I have no idea what happened.
    I used the amp yesterday afternoon and it was perfectly fine.
    Then I switch it on this morning and it won't work.
    It's a Sony STR-DE515 that I bought three years ago.
    Whenever you turn it on, you have to wait a few moments, then you hear a relay click and you get sound however as of this morning when you turn it on and wait a few moments you don't hear a click, instead it blinks "PROTECT".
    I opened the case and saw nothing visually bad (at a glance) and I hit it a few times, just in case the relay was somehow stuck. That didn't work either.
    Visually all the caps look okay and I don't smell anything burnt so nothing went poof.
    What happened? Did the output transistors or something go?
    My entire home theater system is effectively useless without this receiver and I don't have the budget to buy another one.
    Find Nedry!
    Check the Vending machines!!
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Sony amp "protect" issue
    Maybe the transformator got too hot or overloaded: try unplugging the power cable for 2 or 3 hours, then check all cables (e.g. loose conncections, bad rca plugs and such).
    If this don't work, I found something on a forum [1]: it seems some caps and resistors may be damaged.
    Zandrax
    [1] http://forums.afterdawn.com/thread_view.cfm/99866
    Have an happy life.
    • pentium
      • Mar 2006
      • 2778
      Well leaving it unplugged didn't help (as I expected as it was well ventilated, as an amp should be) and I didn't see any similar damage like that other guy had.
      Find Nedry!
      • arneson
        • Sep 2005
        • 1267
        The service manual is offered here:
        http://cgi.ebay.com/Sony-Receiver-ST...2em118Q2el1247
        It's easy enough to lift the legs of the outputs.
        Just takes a few minutes, then plug in the headphones and plug in the unit.
        It tells you where the problem is and allows you to test each output pair.
        Jim
        • pentium
          • Mar 2006
          • 2778
          Sorry but I'm not purchasing the service manual.
          Find Nedry!
          • Spacedye69
            • Nov 2005
            • 698
            • US
            Did you read this?
            https://www.badcaps.net/forum/showthread.php?t=4230
            I found lots of bad solder joints.
            • pentium
              • Mar 2006
              • 2778
              Okay then, I guess I'll take the rest of the unit apart and inspect it a little more and keep out for bad joints.
              Find Nedry!
              • pentium
                • Mar 2006
                • 2778
                First off I found the service manual for the receiver here.
                Okay so I went and pulled the main PCB from the unit and dusted it off.
                For starters, pretty much all of the caps in this are either Nichicon or Rubycon.
                I can also now see that the area around IC701 is a bit brown and so is the area around R807-R809 and C801.
                Other than that I see no charred parts nor do I see any cold joints (but I bet you there are at least two hiding on this board).
                EDIT: Looking at the diagram for IC701 there is something inside the IC marked "protector". I think this might be it.
                Find Nedry!
                • Wizard
                  • Mar 2008
                  • 2296
                  Reason it went into protect mode is the outputs either failed or leaky or open and drive circuit went out of tolerances or blown in act of the main outputs failure. When this happens, you will see DC of some voltage instead of very small millivolts on the output terminals.
                  Cheers, Wizard
                  • pentium
                    • Mar 2006
                    • 2778
                    When you mean output terminals you mean the speaker jacks?
                    Will plugging a voltmeter into the speaker jacks determine the problem?
                    Just want to know as I have the whole unit disassembled and I don't to be putting it back together, only to tear it apart again, over and over.
                    Find Nedry!
                    • pentium
                      • Mar 2006
                      • 2778
                      Okay, I partially reassembled the thing (screwed the board back into the case) and then plugged my voltmeter in to the left speaker jacks. With the system off it's reading .29 volts.
                      After switching it on it jumps to 1.4 volts.
                      EDIT: I did it again and this time I didn't get the protect until AFTER I hear that relay click, at which point it jumps to 1.66 volts and then a moment later I hear the relay click again and "PROTECT" blinks on the screen. I also have two heatsink clips on IC70 to dissipate any heat it's generating.
                      EDIT, AGAIN: I don't know what I did but it's working now.
                      For the heck of it I'll let it warm up and play with the volume a bit and then reheat the joints on IC701 as I did wiggle it a few times. I might also look into gluing a heatsink onto IC701.
                      Find Nedry!
                      • pentium
                        • Mar 2006
                        • 2778
                        Okay, now I got it to a point where it's intermittant.
                        Sometimes it will go into circuit protection immediately, other times it takes a few more moments.
                        Find Nedry!
                        • zandrax
                          Hit and miss
                          • Dec 2007
                          • 1157
                          • Italy
                          Hmm ... fake contacts kept in contact by the heatsink? Overheat? Really I have no clue
                          Zandrax
                          Have an happy life.
                          • Wizard
                            • Mar 2008
                            • 2296
                            1.6 is too high of offset. should be very small volts floating in millivolts like .03V or so.
                            Tear it completely apart but keep heatsinks on the power modules if it is hard to take apart so you can see all the solder points and go over them with your magifying glass and resolder bad joints. Sony is famous for this.
                            Majority of audio ampifers are totem pole transistors ampifer between 2 isolated supplies (+ and -) and drive one side of the speaker from midpoint of the totem pole ampifier to the ground.
                            For this reason, the checks is to see why amp is going into protect is this.
                            When it's working right, the two ampifier transistors are being driven EQUALLY at rest making some heat and floating very small volts at the point in respect to ground potiential. Also it ahs extra circuits to make the cross over point LEAST distortion (no hump or lumps in the waveforms at the zero crossings).
                            This is where lot of work is spent for BEST quality audio and this is where cost makes the difference betwene lousy one and the NICEST sounding ones.
                            Also the drive circuits quality do matter not to "color" the audio.
                            Cheers, Wizard
                            • pentium
                              • Mar 2006
                              • 2778
                              I'm a little lost here.
                              I already managed to completely pull the main PCB out and I have gone over the board at least twice.
                              Could you at least narrow down the places to check by pulling an image out of the service manual and circling it for me?
                              Find Nedry!
                              • Wizard
                                • Mar 2008
                                • 2296
                                You haven't detailed the design of this amp.
                                Is it BIG black ICs with row of pins for each? or many individual transistors (big ones on the heatsinks)?
                                At any rate we mean the drive circuits that forms correct signals to take out the zero crossing distortation that drive the main POWER ampifiers. Bad joints is very fine crack on hot stuff and any that vibrated loose. Need magnifying glass (5X or 10X).
                                detail on the push/pull (aka totem pole output)...this is vast majority of A and AB class amps out there. There are chopper output ampifiers using a coil and fake out a audio waveforms to the speakers that's another different ball of wax thing to discuss later.
                                http://en.wikipedia.org/wiki/Class_A_amplifier#Class_A
                                Cheers, Wizard
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Okay, the part that I seem to be the most concerned about is the vertical standing IC seen in the center of this photo.
                                  It is the one that gets hot (you can see the PCB under it is a little brown)
                                  Find Nedry!
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    All of the area, yours is descrate transistors for amp on (heatsink).
                                    I'm talking about WHOLE lot of stuff between the signal to the drive circuit and the ampifiers. Bunch of resistors, transistors, inline IC, and small transistors (TO-92) etc.
                                    Not small area. Whole. Because one of them have bad joint somewhere. And others are close to break solder joints too. That why need to inspect real carefully.
                                    And yes, Sony is SLOPPY wth heatsink grease! :p
                                    Cheers, Wizard
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Wait, so you pretty much recommend I go with the iron and just reheat every joint on the board?
                                      I really did not understand your last post.
                                      Find Nedry!
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        LOOK! you will find cracks and iffy looking solder joints. Need magnifying glass to find these. I did say the whole area that you taken the picture for this. This means the circuits for the row of big transistors, area about 3" out in front of them.
                                        These are our daily job to search for these bad joints (usually the first thing to do) and check components are in spec with ohm tests and diode checks (transistors are like 2 diodes too).
                                        Cheers, Wizard
                                        • eclectric
                                          Sony Bravia KDL-70W850B T-CON board / software update issue
                                          by eclectric
                                          Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                          In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                          Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                          I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                          05-23-2022, 01:25 AM
                                        • Akuanka
                                          Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
                                          by Akuanka
                                          I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
                                          Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
                                          Thanks in advance for your help!
                                          11-23-2024, 01:12 PM
                                        • GraphicMan
                                          sony sdm-p234 very rare issue never seen before
                                          by GraphicMan
                                          The monitor is old yes but occasionally used (perhaps about 1 ~2 hours usage per day on average)
                                          one time i turned the pc on and noticed this issue
                                          what could it be?
                                          nothing wrong is seen when it is off, also the issue is not there on a green screen!
                                          when watching movies it is hard to detect unless in black screen/large shadows
                                          please check the images, thanks...
                                          04-14-2024, 10:06 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
