Logitech PORTABLE SPEAKERS Z515
  • jpdo
    • Jul 2013
    • 23
    • Portugal
    Hi guys,
    I have an Logitech PORTABLE SPEAKERS Z515 but the spekar dont turn on and don't turn on any light, even when its connected to a charger.
    I have checked the charger voltage and its ok.
    What can be?
    Anyone have the schematic of that board?
  • Widget
    Logitech R20 speakers - Replacing one of the speakers.
    by Widget
    Hi guys,
    I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
    Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
    Printed on the back of the Logitech speaker is;
    LOGITECH...
    05-29-2024, 07:07 AM
  • dreamlayers
    Weird clipping on Logitech Z-10 speakers
    by dreamlayers
    I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
    05-22-2025, 11:41 AM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • nikolayu
    Dell Latitude 5420 wont turn on when charger is connected
    by nikolayu
    I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
    Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
    The same thing if I connect to other USB C port.
    Charger is OEM
    03-13-2024, 12:34 PM
  • vdrokko99
    MBP wont turn on Only green light on charger
    by vdrokko99
    I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
    SMBUS_SMC_BSA_SCL 3.5V
    SMBUS_SMC_BSA_SDA 3.5V
    12-01-2024, 12:18 PM
