This 30+ year old Harman Kardon hk680i has a pair of identical caps (C23 & C24) that appear to have both leaked. These two caps sit on a board identified as the “power supply p.c. board.” I want to find equivalent or better new caps and replace these bad original caps.
Here is what I know about those two caps so far:
TK brand
2200uF +50% -10%
16V
85 deg C
“C-340” ?
height: 1”, 25mm
diameter: 5/8”, 16mm
lead spacing: 5/16”, 8mm
My problem is that I don't think I know enough about the original caps to select an optimal replacement. Neither Digikey nor Mouser show any TK brand electrolytic caps. And then there are additional selection attributes presented by Digikey and Mouser. What about tolerance, ripple current, ESR?
I assume can I safely specify slightly higher voltage and slightly higher maximum operating temperature for better longevity.
Is there anything about the context of the circuit in the schematic that would influence the cap selection?
Anyway, any input that would help in selecting a replacement cap would be appreciated.
TK brand
2200uF +50% -10%
16V
85 deg C
“C-340” ?
height: 1”, 25mm
