Bose Wave Radio 1994 ac hum
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    i've got an old bose awr1-1w from 1994 that i re-capped. almost all of them were bad. most tested with esr of over 30 some over 100.
    it works now, but when first plugging it in and turning it on the speakers will play whatever sound i am giving the unit but also an ac hum that gets louder until it clips the sound levels and then it automatically mutes itself (possibly self-protection?)
    if i mute and un-mute a few times the hum gets softer and softer until its pretty much gone and can only be heard less than inches away and also plays the audio clean after this. what could be going on here? maybe one of the caps has a bad solder joint or could i have used a wrong value somewhere? weird thing is the hum doesnt seem to get softer while its on, only in the transition from and to mute.
    should also be noted it looks like the speakers have a slight dc offset, just a tad pulled in when turned on.
    • 31013
    Re: Bose Wave Radio 1994 ac hum
    could be a ground problem.
    i would re-check the soldering.
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      One of the capacitors reversed?
      sigpicThe Sky Is Falling
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I would think they would have some DC offset pots somewhere on the board. Do you have a schematic to it?
        • R_J
          • Jun 2012
          • 9535
          Is the main filter cap. C401 ? whats the voltage reading on it? (+13.5) and did you replace it? if yes, what value did you replace it with?
          • jasonbay13
            • Jul 2014
            • 185
            • usa
            i have had the thing plugged in but "off" all day and when i turn it on i do not get that hum, i have not checked to see if just waiting a while before trying to turn it on helps.
            i may check all the solder connection and reversed caps.
            dc offset pots? i do have a schematic, but not a service manual. looks like i actually have the 1993 version, attached the schematic.
            the main filter cap is the only one i did not replace as it looked to be in shape still based solely off of esr and dmm capacitance test. leakage unknown. only electrolytics were replaced.
            i shall get a voltage off it when i pull it back apart to check connections/values/polarities.
            • Longbow
              • Jun 2011
              • 623
              Dr. Huckstable, you have failed to describe the villainy. Before replacing all the capacitors was the unit completely dead? There are a lot of electrolytic capacitors in this unit. Hum in both speakers? Present in the line outputs? Power supply voltages correct?
              Is it plugged in?
              • juliadream
                Otaku Mode
                • Dec 2015
                • 44
                I've seen one diode in a bridge rectifier play these kind of heat related tricks.. and also voltage regulator chips.. they leak at only specific temps.. above and below they are just about acceptable.. which might explain why it's a very low hum again once the machine has been allowed to get up to operating temps after peaking during the warmup cycle..
                Shouldn't be that hard to hunt down with a meter on ac range.. the culprit should be pretty obvious.. I'm going to point nice long accusing fingers at U401 and 2 .. they are responsible for the +12 and +5v supplies which feed all the low signal level circuitry..
                • frenchwine
                  Help in diagnosing a Bose Wave II radio.
                  by frenchwine
                  My first post here.....I got hold of a Bose Wave II radio (pic attached) which was not giving out any audio at all. Over the weekend, I managed to change all the SMD caps on the radio (all except the ones in the shielded can that houses the uP) to leaded ones from Panasonic and Nichicon and relieved that the radio now powers up normally and plays audio thru the speakers.
                  However, I have 2 strange issues.......
                  a) The headphone jack gives no audio out.....when plugging headphones, the speakers mutes as they should , but I hear zilch on my headphones.
                  Do these...
                  05-09-2022, 06:46 AM
                  HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                  This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  09-12-2024, 03:44 PM
                  HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                  This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  09-12-2024, 02:00 PM
                • shelby5041
                  clock radio / radio lifespan?
                  by shelby5041
                  hi
                  ive got a modern digital clock radio approx 15yrs old
                  my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                  since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                  the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                  it uses very little power just a few watts i would imagine that may have something...
                  09-14-2024, 03:30 AM
                  HP Pavilion Wave 600-a055cn Pavilion Wave i5-6500T Specification for Upgrade or Repair
                  This specification for the HP Pavilion Wave 600-a055cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a055cn boardview and Pavilion Wave 600-a055cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
