KORG USB MIDI keyboard microKEY-37 has 2 fried SMD components near USB connector
  • triplefour
    • May 2014
    • 1747
    i got this midi keyboard for 5$ untested, and of course, it doesnt work. doesnt do anything when you give it usb power. i took it apart and near the usb connector i saw that a couple of the SMD components looked charred. i scratched with my fingernail and one of them came loose. they are too small and burnt to tell what they were supposed to be, and of course i cant find any service manual for this device, let alone the individual board inside.
    it is marked KLM-3022-D and i can't seem to find a replacement. it seems like it could be an easy fix if i knew what smd components to buy and solder back in place. can anyone help me? are there standard components like this usually found around USB power inputs? they are labeled C2 and L1 .. i assume C2 is some kind of SMD capacitor, but what is L1 ?
    this keyboard is actually pretty slick and is not cheap to buy new:
    http://www.ebay.com/itm/KORG-USB-MID...UAAOSwYHxWF93t
    any help will be greatly appreciated. thanks!
    Don't fear the repair...
    • 31269
    Re: KORG USB MIDI keyboard microKEY-37 has 2 fried SMD components near USB connector
    c2 is a capacitor, if it's not shorted then it's o.k.
    l1 is an inductor - you can probaby get away with a jumper.
    now here is the problem.
    the only way the inductor goes up is if something is shorted.
    • triplefour
      • May 2014
      • 1747
      So should I try to find the short first? Whats the general method for finding shorts?
        • 31269
        first, use a meter to check the 5v and ground pins on the usb connector.
        check the ground goes to ground,
        and see if the 5v goes to that inductor.
        if it does, see if both go to that cap.
        i suspect the cap is across the power, and the inductor is inline with the 5v
        but i'm interested if the cap is on the connector side of the inductor or the board side.
        • triplefour
          • May 2014
          • 1747
          ok i used my meter on diode mode and listened for the beep to look for shorts but i couldnt find any. there are 3 usb connectors on this board (2 of them are outputs, like a usb hub thing, im guessing) and the one square on is for input. each has 4 pins. on each connector, one of the pins has continuity to ground and the other 3 do not. the inductor and cap circuit is repeated for the other 2 connectors and studying those, i was able to figure out to jumper the pad that would have went to L1 properly to the + side of the cap. it doesnt look pretty... but i guess im ready to plug in a usb and measure voltages?
          • triplefour
            • May 2014
            • 1747
            hey what do you know, i plugged it in, and windows made the noise, and started trying to find the drivers on windows update...and it found em now to put this whole thing back together and see if it plays!
            • triplefour
              • May 2014
              • 1747
              awesome. everything seems to work fine now. thanks stj!
              • Khron
                • Sep 2006
                • 1350
                • Finland
                I wouldn't be entirely shocked if C2 had failed shorted - it wouldn't be the first time i've seen ceramics short. That's how i've revived several laptops in the past.
                Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                • triplefour
                  • May 2014
                  • 1747
                  i checked c2, it was not shorted. just had to jumper across L1 and all is good
                    • 31269
                    maybe it got taken out by something plugged into one of the other usb ports.
                    i'v seen people do some really stupid shit with usb.
                    one guy blew the ports on a ps3 trying to charge his phone from one!!!
                    • triplefour
                      • May 2014
                      • 1747
                      shouldnt it normally be ok to charge ur phone via the ps3?
                        • 31269
                        no, the ports are only intended for the controllers or memory-sticks.
                        they arent intended to supply 500ma-2A that a phone may try to pull
                        • triplefour
                          • May 2014
                          • 1747
                          oh wow good to know!
                          • Tomylee
                            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                            by Tomylee
                            Sorry for the person who’s going to read all this !
                            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                            07-11-2025, 11:52 AM
                          • zombie.guitarist
                            Reading Serial Midi data with an oscilloscope
                            by zombie.guitarist
                            Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
                            The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
                            When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output...
                            07-05-2023, 09:29 AM
                          • 5mall5nail5
                            Help identifying connector for ASUS 4090 Strix RGB LED connector
                            by 5mall5nail5
                            Hi All -
                            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                            05-04-2025, 07:47 AM
                          • bussincaps
                            MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                            by bussincaps
                            Hello All,
                            tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                            Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                            eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                            Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                            I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                            08-03-2023, 12:57 PM
                          • michhak
                            Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                            by michhak
                            Hi guys,
                            i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                            It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                            11-17-2021, 05:45 AM
